Old 01-14-2011, 14:18   #1 (permalink)
Shubhanshu~'s Avatar
Member: 65074
Sonork: 100.1611263
Thanks Meter: 214
Unable to Repair IMEI in Voice V41 !!
I am Unable to Repair Imei in Voice V41 Handset..
Its New firmware
New firmware found (v.3.26, database date: 23.12.2010):
DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.T68D_V41_L201_ET.BIN
Files sent to Support.
Tried Safe format, Full Format, Imei Mode 1, mode 2 & Mode 3 Also Default IMEI inside firmware, But Even Though it says Success, when Checked at Handset or at General info, Same..
Action: read/check information
Model: Autodetect 6205-6239 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6225, E05
Hardware version: DEWAV25_GEMINI_HW
Software version: T68D_V41_L201_ET"
Software date: 2006.06.14
Barcode: MT012345678901234567
imei-1: #98999+9"
imei-2: #98999+9"
imei-3: #98999+9"
Finished, time used: 3 sec
Remove/Install battery now !
Please Support This Firmware.
Any Urgent Help will be Helpfull!
Thanks
Old 01-14-2011, 20:33   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what IMEI is shown via *#06#?
please show Mode-1 changing log
Old 01-14-2011, 23:04   #3 (permalink)
Member: 212545
Sonork: 100.1669621
Thanks Meter: 5
any sol for spreadtrum ic formating or flashing tool without pinfinder
such as MTK flashing tool
any body hellp
Old 01-15-2011, 08:46   #4 (permalink)
Member: 65074
Sonork: 100.1611263
Thanks Meter: 214
hello!
Set Displays Same IMEI ie. #98999+9"
Here is Mode - 1 Log
Imei 35------------ already was repaired: 14/Jan/2011-6:58:25 PM
Continue with this imei ?
Action: "repair imei"
Connecting, wait...
imei-1: #98999+9"
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei-1: 35------------
verification Ok
Finished, time used: 5 sec
Here is the log for default IMEI inside firmware
COM3 [VCP0] selected
module  v3.26
Device: Autodetect 6205-6239 NOR
imei write channel: imei #1 (default imei inside firmware)
new imei: 35-------------
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:A203:0007
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 98000300000001:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
921600
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 04
sw version: DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.T68D_V41_L201_ET.BIN
project-id: T68D_V41_L201_ET, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
Backup required data Done
====>  Patch required data ...
detecting ffs/eeprom structure pass 2...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok element #2
imei default found: 35-------------
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write: imei
Write Done
====>  Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 1 min 59 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Thanks
Old 01-15-2011, 09:49   #5 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Try with option "AutoDetect 6253 NOR" in Model tab.
I found it in one phone and after choosing this option it succeeded.
So you can try out.
Wr.
Old 01-15-2011, 12:08   #6 (permalink)
Member: 65074
Sonork: 100.1611263
Thanks Meter: 214
Thanks lot mate for the reply, But It doesn't worked for me!!
Log
Model: Autodetect 6253 NOR
Connecting, wait...
imei-1: #98999+9"
verification Ok
Finished, time used: 4 sec
Old 01-16-2011, 14:39   #7 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Now what remains is you can try to write firmware from another same working phone and then try.
Wr.
Old 01-16-2011, 21:28   #8 (permalink)
Member: 148515
hello!
make full backup and try following flash file:
flashfiles/ChineseMiracle/_MT6225/DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.T68D_V41_L200 _ET_16m_En.B0M.bin
Old 01-17-2011, 21:52   #9 (permalink)
Member: 212545
Sonork: 100.1669621
Thanks Meter: 5
i solv the problem with dragoan box this box is very high speed going so many freature in
Old 08-13-2011, 11:45   #10 (permalink)
Member: 1188586
voice v41 imei not repair,how can with details
reading: DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.T68D_V41_L201 _ET__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\DEWAV25_GEMINI_PC B01_GPRS_MT6225_S00.T68D_V41_L201_ET__ffs_20110813-160631.B0E.bin
flash: 98004900000002:18E59F00000000
4 step(s) required
====> Write ...
flash: 98004900000002:7B717A00000000
Write: ffs
Write Done
Finalization Done
Finished, time used: 3 min 12 sec
Old 08-14-2011, 20:13   #11 (permalink)
Member: 148515
hello!
please try IMEI change mode-1 or mode-2
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.23243 seconds with 9 queries
