Old 02-22-2009, 05:58   #1 (permalink)
Member: 86531
Unlock JinPeng S4166 CPU AIT605G Done.
Run module Pana01, select ZTE-123
COM2 [VCP0] selected
module v1.62
Device: ZTE-123
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-static_20090222-113645.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-security_20090222-113646.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-complete_20090222-113647.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_lock-area_20090222-113652.B1E.bin
backup critical area Done
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 25 sec
Remove/Install battery now !
The Following User Says Thank You to TX101 For This Useful Post:
Old 03-27-2009, 15:52   #2 (permalink)
Member: 569910
Thanks Meter: 11
JinPeng S4166
Phone is lock code
I'm User/phone/lock code
COM9 [VCP0] selected
module v1.60
Device: ZTE-123
Action: reset
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
460800
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-static_20090327-214919.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-security_20090327-214920.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-complete_20090327-214922.B1E.bin
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Finished, time used: 18 sec
but Phone is not power on
Please help me full flash
thank !
Old 03-27-2009, 21:50   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
does phone was working before this operation?
Old 03-28-2009, 03:13   #4 (permalink)
Member: 569910
Thanks Meter: 11
hello!
Hello InfinityHelp !
Thank for reply
Before this operation phone is lock code .
Old 03-28-2009, 14:42   #5 (permalink)
Member: 148515
hello!
please load file "ZTE-123_eeprom-complete_20090327-214922.B1E.bin" as eeprom
write back to your phone.
check if it is powering On , read full backup out and send to us
we will add support for this model
Old 03-29-2009, 15:53   #6 (permalink)
Member: 569910
Thanks Meter: 11
hello!
Thank you for reply , i'm flash backup eeprom_complete , yes > phone is power on ok !
Thank for InfinityHelp !
module  v1.60
Device: ZTE-123
Action: flash write
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
460800
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-static_20090329-212928.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-security_20090329-212929.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-complete_20090329-212931.B1E.bin
Check memory ...
Check memory Done
Write ...
reset...
done
Erasing: Eeprom
Writing: Eeprom
Write Done
Finished, time used: 35 sec
Old 03-29-2009, 16:18   #7 (permalink)
Member: 569910
Thanks Meter: 11
Eeprom JinPeng S4166 UPP :ARM AIT605G ok download
Old 03-29-2009, 21:16   #8 (permalink)
Member: 148515
hello!
we need FULL flash backup (read full flash)
send it to [email protected]
attach this photos and problem description
thank you!
Old 03-30-2009, 05:09   #9 (permalink)
Member: 569910
Thanks Meter: 11
hello!
thank you!
Modell not read full by box infinity , I'm selec read full flash > files read 770KB
Old 03-30-2009, 05:22   #10 (permalink)
Member: 569910
Thanks Meter: 11
flash size 4MB , files read by Vepro : Ve-infineon = 4MB
Old 03-30-2009, 20:14   #11 (permalink)
Member: 148515
hello!
please post file read by infinity box.
this is important
Old 01-28-2011, 16:37   #12 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Hi Infinity Team
I Have Also CPU China Mobile Phone
CPU: AIT605G 0734-CST90
Flash Chip: Spansion
I Want To Write Correct IMEI Here Is Log
module  v1.73
Device: Vodafone-123
Action: "repair imei"
new imei: 35385XXXXXXXXXX
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-123_eeprom-static_20110128-201249.B1E.bin
loading data...
wrong database file: C:\Program Files\InfinityBox\Pana01\z125_eep65535.cfg
error: can't load database v.62962
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-123_eeprom-security_20110128-201250.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-123_eeprom-complete_20110128-201256.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-123_imei-area_20110128-201315.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-123_lock-area_20110128-201334.B1E.bin
Check memory ...
lock found
lock type #1 found
error: unknown firmware, read flash and send to support
Check memory Failed
Finished, time used: 1 min 18 sec
Finished
After Write IMEI Mobile Is Completely On. Then I Try To Reset settings,format ffs
After This Process My Phone Is Dead
Have I Any Chance Again My Mobile Alive ?
If No Don't Worry, But Sir Please Will Support This CPU.
Because Not Support Yet Any Other Box Or Tool
Old 01-30-2011, 20:20   #13 (permalink)
Member: 148515
hello!
have you done full backup before killing it?
Old 01-31-2011, 18:35   #14 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
hello!
No Sir I Haven't Backup But I Want To Please Support This CPU
Old 01-31-2011, 22:39   #15 (permalink)
Member: 148515
hello!
good working backup is need for supporting it
c123 unlock without remove cpu soy Infinity-Box 4 10-09-2008 13:30
startech 67 dual cpu restart done by infinity twentyonecell Infinity-Box 3 09-05-2008 12:45
New china CPU AIT605G spyer SpiderMan 3 06-15-2008 07:20
Unlock All Mtk Cpu smart_mobile Chinese Models & Cloned Phones 3 11-16-2007 09:21
Page generated in 0.23575 seconds with 9 queries
