Old 05-31-2018, 00:46   #1 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
nead gpt partition to revevie a dead oppo f1s
hi all, i have a dead oppo f1s, succesfully flashed with a file found on forum "up_vnROM.net _MT6750_OPPO_F1s_100%" , but still dead, and other files can't flash anymore, always error.
after some search, i got an advice from a member, he told me that i have a flash " gpt partition " this file can be red from a working phone, then after that i can flash my phone with full flash and revive it.
can anyone give this fille ? gpt partition..
log with CM2MT2 :
Reconnect Power/Cable!
Operation : Write Flash [ v2.00 r3 ]
Repartition  : Enabled
Flash Verify : Disabled
Pre-Erase    : Enabled
Verify HW/SW : Enabled
XData Backup : Disabled
Files :17
[FL] : Set : preloader.bin
[FL] : Set : recovery.img
[FL] : Set : md1rom.img
[FL] : Set : md1dsp.img
[FL] : Set : md1arm7.img
[FL] : Set : md3rom.img
[FL] : Set : lk.bin
[FL] : Set : lk.bin
[FL] : Set : boot.img
[FL] : Set : logo.bin
[FL] : Set : trustzone.bin
[FL] : Set : secro.img
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0xCB57804C [ 3,18 GB ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MTK USB Port (COM44)
MODE : BOOTROM
PORT : 44
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
     TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000000
BROM : SecMode  : PLAIN [+PRL]
BROM : BOOTROM
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6755
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
DA : EXT_RAM NOT initialized!
     EMI : DEV : MT6755
     EMI : SRC : preloader_oppo6750_15131.bin
     EMI : CNT : 0009
     EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100524531424D42 : VEN : SAMSUNG   | DEV : RE1BMB : RAM : [ 3,00 GB ]
     EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 90014A484247346132 : VEN : HYNIX     | DEV : HBG4a2 : RAM : [ 3,00 GB ]
     EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525831424D42 : VEN : SAMSUNG   | DEV : RX1BMB : RAM : [ 3,00 GB ]
     EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 13014E51334A393756 : VEN : UNKNOWN   | DEV : Q3J97V : RAM : [ 3,00 GB ]
     EMI : [04] : eMCP : eMMC+LP/DDR3 , ID : 150100525831344D42 : VEN : SAMSUNG   | DEV : RX14MB : RAM : [ 4,00 GB ]
     EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 13014E51334A393757 : VEN : UNKNOWN   | DEV : Q3J97W : RAM : [ 4,00 GB ]
     EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100524331344D42 : VEN : SAMSUNG   | DEV : RC14MB : RAM : [ 4,00 GB ]
     EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG   | DEV : RH64MB : RAM : [ 4,00 GB ]
     EMI : [08] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 4,00 GB ]
     EMI : Init EMI from PRELOADER
     EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : BOOT 2ND DA FAILED!
ERR : 0xC0070004
ERR : DA_HASH_MISMATCH
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
thanks
Old 05-31-2018, 10:17   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
GPT created during flashing procedure.
You not need it.
Interest is how you bring device to that condition.
Old 05-31-2018, 10:35   #3 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
You not need it.
I received the phone dead, custer said that it was dead after soft reset.
Old 05-31-2018, 10:49   #4 (permalink)
JayDi's Avatar
Member: 462970
Device not accept second DA, so, probably there is problems with flash or device itself.
Or someone flashed signed preloader with some "enable fuse" code.
You can't boot it at all.
So, before GPT there is a problem. Have no idea how override it right now.
Old 05-31-2018, 10:53   #5 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
Thanks for info, i'll try to find something to fix, or bring it back to custumer, maybe uts hw problem.
Old 05-31-2018, 10:56   #6 (permalink)
JayDi's Avatar
Member: 462970
I can advise just to desolder flash or use ISP connection and try to write it over some emmc tool. But chance is also not big.
Old 05-31-2018, 11:00   #7 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
Yes i'll reheat flash ic and see, thanks
Old 05-31-2018, 11:20   #8 (permalink)
Member: 1882912
Sonork: 100.1677703
Thanks Meter: 263
you can try
oppo 32gb
EMMC: 13014E51334A39375610028E15479359
EMMC: VEN : UNKNOWN | OEM : 4E01 | DEV : Q3J97V
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x747C00000 [ 29.12 GB ]
https://mega.nz/#!61VlRbyb!SRt_Fottm...DcKsWK9fvRmX0Q
oppo 64gb
EMMC: 150100524331344D4201E947CAFC138B
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RC14MB
EMMC:
USER : 0xE8F800000 [ 58.24 GB ]
https://mega.nz/#!vo8y3JZT!svIx6TzBD...-XNmPoV50ra9lw
Old 05-31-2018, 11:22   #9 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
Originally Posted by MDxavi View Post
you can try
oppo 32gb
EMMC:
oppo 64gb
EMMC:
Thank you so much, i'll try them and post result
Old 05-31-2018, 11:32   #10 (permalink)
Member: 1948608
Thanks Meter: 1,744
if the flash IC is blank nd no partition than how u Init Device wit Memory tool...?
Old 05-31-2018, 14:55   #11 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
i think you are right, i got error when try to init device with memory tool cm2mt2.
Operation : Memory Tool Init [ v2.00 r3 ]
MODE : BOOTROM
PORT : 44
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : INFINITY
     EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
     EMI : CNT : 0009
     EMI : Init EMI from INTERNAL DB
ERR : 0xC0070004
last chance to rehoot flash ic.
thyank you all.
Old 05-31-2018, 17:20   #12 (permalink)
JayDi's Avatar
Member: 462970
Not sure about rehot will help.
There is need to try program it via external emmc hw.
Then, if result will be same at boot and no power one - then it CPU.
The Following User Says Thank You to JayDi For This Useful Post:
Old 02-18-2021, 21:36   #13 (permalink)
Member: 2622185
Sonork: 100.1675196
Thanks Meter: 19
Now What to do?
memory tool initialized successfully, but sgpt partition write error, whats the problem, team
Old 02-18-2021, 22:02   #14 (permalink)
Member: 2185549
Thanks Meter: 535
as far as i know GUID Partition Table
is the so called gpt so why do u need it when the tools can create it corresponding with the scatter files and the preloader partition so in this case you might need to boot it picking settings from compatible emi /preloader because looking at the log it doesnt boot the phone to have acces to emmc if this fails remove isp put it to any jtager z3xjtag,ufi,medusa,riff watsoever try to write corrct firmware after formatting emmc and make sure the firmware is correct some emmc security doesnt allow to flash secure partitions like preloader nvdata nvcfg nvram e.t.c depending on vendors specifications and limitations
best practice reprogramm emmc with any jtager thank @jaydi later
Page generated in 0.30681 seconds with 9 queries
