11-12-2015, 08:22 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: pakistan
Member: 1466124 Status: Offline Thanks Meter: 116 | urgent help rock chip tablet dead with infinity format resat with infinity , after format tablet not going on , always on boot mode not exit boot mode i reconnect battery but same situation what i dooooo Found active FlashInterface , connecting ... Detected : RK2928 Read Info Ok! Format FS/Reset Settings accepted by User! Operation : FormatFS / ResetSettings [ v1.0 ] Init UserData Init Cache Init IntSD Init Ok! Format prepare Done! Wait, until device reboot Elapsed: 00:00:00 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK2928 Read Info Ok! |
11-12-2015, 08:58 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It will stay in boot mode only due next reasons : 1. It have pressed keys 2. It erased completely ( need make separate operation, which CM2 will not do at all. Even if user want it. 3. It flashed with wrong FW. SW have also button for reboot. It works as well. |
11-12-2015, 09:10 | #5 (permalink) |
Member: 1466124 Status: Offline Thanks Meter: 116 | 1 not press any key i complete cheak 2 not erase completl cheak this ........ i read patron lock and see detail Reading PatternLock ... Decrypt PatternLock Sequence : 954781236 Elapsed: 00:00:04 3 not flash wrong firmware before this tablet on and working just one click format/reset settings and tablat going dead and permanent download mode and not on with reboot button |
11-12-2015, 12:38 | #10 (permalink) | |
Member: 1466124 Status: Offline Thanks Meter: 116 | Quote:
but i think tab not format i try many time but infinity not other but pattron and tab not resat if resat then pattern sequence not show thxxxxxx | |
11-12-2015, 12:49 | #11 (permalink) |
Junior Member Join Date: May 2014
Member: 2182076 Status: Offline Thanks Meter: 1 | infinty dont dead phones or tablet like other tools so before your post check your tablet power reinstall your battery then insert your usb cable or charger and tell us what is the result i am sure your tablet is working |
11-12-2015, 13:00 | #12 (permalink) | |
already disconect and reconect battery and cheak volume and power button before this all button working well | |
11-12-2015, 15:09 | #15 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I see nothing strange here. I still sure about there is problem with tablet itself. It can't die after simple operations, if it ok by HW. |
