02-13-2009, 08:40 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: 5AAB Age: 37
Member: 167191 Status: Offline Thanks Meter: 363 | alcatel s319x unlock problem now problem is that handset is Ok.. sound is ok but screen is black after flashing with unlock file- handset has previous version and here is the log of handsets previous version: Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 detect device identification#2... anyhelp in this case or anybody have its original file backup to get my handset back gurinder |
02-14-2009, 09:56 | #5 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 304933 Status: Offline Sonork: 100.1618191 Thanks Meter: 49 | full flashed and with eeprom file from support site but set still in lock mode also ffs with flashing any help i flash two set but set in lock mode ple help infinity box |
02-14-2009, 11:44 | #6 (permalink) |
Member: 167191 Status: Offline Thanks Meter: 363 | i tried each and every file on support.. all simfree files on support.. but my handset not unlocked... then as i told about my problem that i got blank screen after flash with simfree files..is revived by flashing with S319X-2GPWGB1_XH16DP32_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-10-29_En_Fr_Es_It_De_Orange-Uk.B0M.bin now i have successfully revived my handset but handset is still locked.. plz... do something for this handset... |
02-14-2009, 12:49 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to flash your locked phone with this file now: http://www.infinity-box.com/download...imfree.B0M.bin Waiting for your results. Last edited by InfinitySupport; 02-14-2009 at 13:15. Reason: link fixed |
02-14-2009, 22:09 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Special file was prepared for your phone: http://forum.gsmhosting.com/vbb/show...00&postcount=7 If your phone flashed now with good locked firmware and has no problems with LCD make this: 1. download file by given link 2. flash phone with downloaded file (make "format ffs" box checked during flash) 3. try to power on phone and see results in case of any problems post here operation log text for flash write operation |
02-16-2009, 10:59 | #10 (permalink) |
Member: 167191 Status: Offline Thanks Meter: 363 | COM1 [VCP0] selected module v2.64 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:1CDB:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090216-150616.B0X.bin Area: Firmware flash: 98004900000002:2AEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CH16JB10 done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 98004900000002:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090216-151226.B0X.bin Finished, time used: 391 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On thnx to infinity team, handset unlocked with this file.. but now problem is language.. language is changed and more problem.. this handset has middle button for selecting purpose called OK. now this OK button opens the menu but not selecting or futher opens the submenu.. example. phone has total 9 menu. so for selection 9th menu.. in this firmware i have to press 9 button from keyboard then submenu will open other wise by pressing OK button on 9th menu.. menu not appearing.. do u understand what i want to say sir... for opening a particular menu.. we have to press that particular similar button on keypad to open that menu. thnx for cooperation to unlock this model but plz.. see about language option and that of also menu openin option. gurinder |
02-16-2009, 11:03 | #12 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | for language pls try to goto settings and make your luck maybe youll get lucky and change language to english...or you can try *#0044# then try to check in settings also bout your problem with the middle button....post result |
02-16-2009, 11:09 | #13 (permalink) | |
Member: 167191 Status: Offline Thanks Meter: 363 | thnx Quote:
how about that problem?? gurinder | |
02-16-2009, 11:37 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, New customization files is ready, please try to flash it one by one and let's see results. Do not forget to make "format ffs" after flashing (or make "format ffs" box checked during flash process). 1. http://www.infinity-box.com/download...imfree.B0M.bin 2. http://www.infinity-box.com/download...imfree.B0M.bin |
02-16-2009, 12:04 | #15 (permalink) |
Member: 167191 Status: Offline Thanks Meter: 363 | menu problem same intact with these files but ok button appears on wap setting options at left upper button.. are these files only customization????? may be that menu have no further sub menu bcoz these files as u wrote are customize.. this is my guess... correct me if i m wrong... may i try again with other files. may be this type of behaviour of handset is by default.... gurinder |
Pls help with alcatel s319x unlock | TALIAT | Infinity-Box | 3 | 08-02-2009 14:12 |
Alcatel S319X unlock done but no service | kemot | Infinity-Box | 4 | 06-20-2009 07:37 |
Alcatel s319x unlock ok but help | Lutfur | Infinity-Box | 0 | 04-22-2009 09:29 |
alcatel s319x unlock problem | zeeshan tayyab | Infinity-Box | 4 | 03-26-2009 07:46 |
Alcatel S319x unlocked in one pass | jepetu | Infinity-Box | 2 | 03-23-2009 12:59 |
