06-14-2009, 14:27 | #1 (permalink) |
Junior Member Join Date: May 2008
Member: 763332 Status: Offline Sonork: rashid Thanks Meter: 3 | v877 need complete firmware please send me its firmware or tell what's the problem. COM12 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:1A03:000F status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:08000C00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:08000C00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:08000C00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:08000C00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:08000C00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:08000C00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 08400C000000078518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.82, database date: 08.05.2009): PROWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.LT526B_R1_0 _39_5.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: PROWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.LT526B_R1_0 _39_5.BIN ver. sw 2: LT526B_R1.0.39.5, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:08000C00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: PROWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.LT526B_R1_0 _39_5__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\PROWAVE25_GEMINI_ PCB01_GPRS_MT6225_S00.LT526B_R1_0_39_5__ffs_200906 14-172709.B0E.bin flash: 98004900000002:08000C00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000002:08000C00000000 Finalization Done Finished, time used: 499 sec Remove/Install battery now ! |
06-14-2009, 18:37 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Code: ==================== New firmware detected (v.2.82, database date: 08.05.2009): PROWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.LT526B_R1_0 _39_5.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== If required file can not be found in support area (please use "search" function in support area first) it will be good if somebody can read full flash from the same good working phone and send full flash backup to [email protected] so we will be able to prepare and upload good working files in support area for all users. Here is an instruction how to make "search" in support area: http://forum.gsmhosting.com/vbb/showthread.php?t=499453 Please, DO NOT send to us backup files from damaged phones. We CAN NOT repair damaged files ! |
please!! i need i8510M complete firmware | NEO-TECH | Samsung Flashers, Software, Firmware. | 1 | 01-27-2012 23:03 |
Samsung D600E D600EXBEK4 Complete Firmware | 399enp | SWIFT Platform | 22 | 01-20-2011 03:46 |
need spacial firmware for U890. who can upload? | Maiwand khan | FuriousGold | 1 | 03-29-2010 15:28 |
please!! i need i8510M complete firmware | NEO-TECH | NSPRO | 0 | 10-31-2009 15:45 |
please!! i need i8510M complete firmware | NEO-TECH | SPT BOX | 0 | 10-31-2009 15:31 |
