06-18-2008, 12:08 | #1 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 599037 Status: Offline Thanks Meter: 103 | v918 critical problem.. what shud i do??plz hlp team Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:0F6C:668D high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: A9EA80F098E59F:A9EA8000000000 flash: A9EA80F098E59F:A9EA8000000000 number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. Fault reasons: 1. damaged flash chip: replace or resolder/reball flash chip 2. damaged hardware: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 110 sec Remove/Install battery now ! what shud i do for that.. i hav even reball the flash chip.... |
06-18-2008, 18:43 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! this 100% bad FLASH <> CPU bad connection. this can be either flash or CPU bad soldering as well as flash IC internal hardware fault |
jump command failed?for c975 what shud i do?? | peter002 | Rocker Dongle (By Legija) | 9 | 11-14-2009 17:07 |
strange problem in ztc zt808. plz hlp team.. | peter002 | SpiderMan | 4 | 12-04-2008 15:08 |
j100i unloking problem. plz hlp team | peter002 | Infinity-Box | 2 | 09-26-2008 08:31 |
strange problem with the smart klip.. plz hlp team.. | peter002 | Smart-Clip | 2 | 09-18-2008 08:42 |
