03-08-2020, 11:49 | #1 (permalink) |
No Life Poster Join Date: Sep 2009
Member: 1128573 Status: Offline Thanks Meter: 242 | ver 2.09 test report 1 report 1 OPPO A1K CPH1923, VER A.26, PIE problem user password lock. identify ok. format ok. passcode still remain, NOT REMOVE. both op full log are : OPPO A1K CPH 1923 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.09 Load IDBase v36128 Ok! Operation : Identify [ v2.09 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM26) MODE : BOOTROM PORT : 26 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : BCBFE50F15A7B18D3E062772FDF4E1637E0E895C3A42A4F660 22D04382F76E0C BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765 AP_SWTM : Sun Jan 5 20:51:32 CST 2020 AP_SWVR : CPH1923_11_A.26_200105_fa6f5268 MD_CHIP : MT6765 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R2.PIE.P22.PR3.TC16.SP.V1.P3 MD_SWVR : OPPO_P0MP3_K62V1_64_BSP_HW MD_HWVR : Unknown Done! Elapsed: 00:00:49 Operation : Reset Settings/Format FS [ v2.09 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM26) MODE : BOOTROM PORT : 26 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : BCBFE50F15A7B18D3E062772FDF4E1637E0E895C3A42A4F660 22D04382F76E0C BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765 AP_SWTM : Sun Jan 5 20:51:32 CST 2020 AP_SWVR : CPH1923_11_A.26_200105_fa6f5268 Format Ok : UserData Done! Elapsed: 00:00:35 Reconnect Power/Cable! with best regards mahir |
03-08-2020, 12:18 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello, as we mention in update logs, some oppo found as not working for format in meta. Device will come on hands soon to try check it and test something. |
The Following 5 Users Say Thank You to JayDi For This Useful Post: |
03-13-2020, 18:50 | #4 (permalink) |
No Life Poster Join Date: Jun 2005
Member: 154448 Status: Offline Sonork: not yet Thanks Meter: 50 | Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.09 Load IDBase v36128 Ok! Update configuration ... Update Ok! Load IDBase v36128 Ok! Operation : Identify [ v2.09 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : 70C72CBE3481CAAB4DEC2ECED0E4FE12A3920DDF2E2FCAC630 846458EEFE9CA5 BROM : Configuring target for META BROM : META configured! INIT : META enter failed by timeout! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
03-14-2020, 05:29 | #5 (permalink) |
Member: 1128573 Status: Offline Thanks Meter: 242 | ROMprovider.com driver auto installer exe v5.1632 download from support site and install. phone power off hold both vol up and down button connect usb phone found quick release all button |
03-14-2020, 06:58 | #6 (permalink) | |
No Life Poster Join Date: Dec 2015 Location: pakistan Age: 27
Member: 2498409 Status: Offline Thanks Meter: 127 | Quote:
its not driver problem oppo lateset patch support only remote flashing ofp file just | |
03-15-2020, 06:51 | #7 (permalink) |
Insane Poster Join Date: Dec 2013 Location: pakistan
Member: 2090485 Status: Offline Sonork: 100.1650866 Thanks Meter: 12 | oppo A1k format Mr JayDI if cm2 can read logs off Oppo A1k,I think it would be flashed ofp file by cm2. may be in nearest coming update.I beleave so. |
