03-27-2008, 17:12 | #1 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Is very big difference between S600 & S600n I see the list and i select the S600 for flashing S600n. Is very Strang difference between these model . . . . ? ? ? I know one difference of them model is Memory. In S600 128 MB space for download & In S600n 256 Mb space for download. Recently I have to ask i use this model for flashing S600n . . . . If YES plz tell me what do the first. |
03-27-2008, 17:26 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, As I can understand you talk about Spice-S600 and S600n. Is it right ? If so, please, make this: 1. read flash from your phone (S600n) 2. send e-mail to [email protected] and explain situation and attach S600n flash file so we can check it and give you an advice. |
03-27-2008, 17:41 | #3 (permalink) |
Member: 343326 Status: Offline Thanks Meter: 1,463 | And also i tell u that i try to connect the phone like this . . . (Please see attachment.) This pinout is Correct or Not i not sure . . . . Plz tell me it is OK or Not . . . . I try to connect the phone like this connection but phone is can't support also i swap the Rx<->Tx wire no result. (And I long press the on button during boot process.) |
03-27-2008, 17:52 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, As you can see at www.infinity-box.com the phone S600n is not listed in supported models list so HOW CAN I KNOW IT'S PINOUT ? Please, be little bit patient and try to find pinout by yourself (try different points on phone) and post here results, so other users will say you big thanks for your work. |
06-07-2008, 09:14 | #5 (permalink) |
No Life Poster Join Date: Apr 2004 Location: nagaur raj Age: 57
Member: 62820 Status: Offline Thanks Meter: 175 | here is spice s600n pinout find with auto pin finder cable type: 1x18 (L18A) platform: MT62xx (autodetect) searching adapter at COM7... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6217 result: Rx:14 Tx:13 time required: 99 sec Power On ! |
The Following User Says Thank You to shantilal For This Useful Post: |
06-07-2008, 09:16 | #6 (permalink) |
Member: 62820 Status: Offline Thanks Meter: 175 | here is read user code with infinity model select spice s600 and read user code spice s600n Action: read codes unlock method: read codes Model: Spice S600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6217:8A00]... CPU: MT6217 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6217,E00 Date: 2004.07.02 Version: 1.1.1.4 Version: P50017.05161210H.S1_05ST Version: G72_HW 65 byte(s) read imei: 35749501067884 connection Ok 69 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 5555 Finished, time used: 12 sec Remove/Install battery now ! |
different between ufs2 & ufs3 | A-Razzaz | UFS2 + UFS3-Tornadoflasher | 8 | 10-13-2004 14:41 |
Difference between US2 & UFS3?? | tronik | UFS2 + UFS3-Tornadoflasher | 0 | 04-12-2004 15:04 |
is the any difference between Victor & Pst com cable? | alexzzander | Motorola P2k | 4 | 02-05-2004 20:04 |
what's the difference between t190 & t191 ?? | genocite | Motorola ODM | 1 | 01-14-2003 22:15 |
what is the sw difference between A35, A36 & A40, if any? | Sztrovacsek | x1x to x45/x50 | 5 | 07-12-2002 07:39 |
