Old 01-24-2009, 16:25   #1 (permalink)
msashami's Avatar
Member: 181213
Sonork: 100.1586186
Thanks Meter: 201
Found pins with pinfinder but unable to
I have found the pins with Auto pinfinder as:
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
CPU: MT6225
result: Rx:5 Tx:4
time required: 23 sec
Power On !
saved: Cect_E900
and saved with the model name cect_E900
but when i try to use it with chinese miracle process dont start as:
COM5 [VCP0] selected
module v2.75
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
error: can't activate test mode
error: operation failed !
Finished, time used: 7 sec
Remove/Install battery now !
what's the problem plz
WBR
Old 01-24-2009, 16:55   #2 (permalink)
Member: 154411
Thanks Meter: 10
hi in pinfinder screen check set power on after find
Old 01-24-2009, 22:18   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
yes, you must check if phone stays powered from pinfinder power.
by checking Power Led on pinfinder.
Iphone found network but UNABLE TO JOIN THE NETWORK dumuc iPhone 2 / iPhone 3G / iPhone 3GS 2 02-08-2010 14:33
n68 connects with pinfinder,but cant connect in chinese miracle GOODNESS Infinity-Box 13 07-24-2008 21:33
LG KG270 Using pinfinder now unable to connect asadnow2k Infinity-Box 2 06-02-2008 13:30
have lost 4credits but unable to unlock k800i indian mobiles SETool2 9 05-25-2007 16:05
6630 network is ok but unable to make a call ashok_kumar459 Nokia Base Band 5 ( BB-5 ) 3 05-17-2006 17:34
Page generated in 0.13442 seconds with 9 queries
