01-09-2018, 19:07 | #1 (permalink) |
Freak Poster Join Date: Feb 2015
Member: 2349228 Status: Offline Sonork: 34610 Thanks Meter: 19 | VFD 610 Frp problem remove frp with cm2 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:30 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:08 |
01-10-2018, 14:33 | #6 (permalink) |
Freak Poster Join Date: Apr 2013 Location: lisbon
Member: 1917749 Status: Offline Thanks Meter: 90 | 10000000% work i did 10+ phones if u have phone on your hand contracet to me skype [email protected] |
01-10-2018, 15:14 | #7 (permalink) | |
Member: 2349228 Status: Offline Sonork: 34610 Thanks Meter: 19 | Quote:
Please help me remove account google for VDF610 Thank you in advance for your efforts | |
01-10-2018, 15:43 | #9 (permalink) |
Member: 1917749 Status: Offline Thanks Meter: 90 | Download Quick Shorcut maker.apk 1- Scarch Setup Wizard 2-touch on Setup Wizard google service/try/next /next/ then phone ask u to slide menu on the top/ go to setting /enable adb /make hard reset if not work try same way Setup Wizard google service 3rd option Tool Easy 1000000% done |
The Following User Says Thank You to anamul123 For This Useful Post: |
01-10-2018, 17:14 | #12 (permalink) | |
can explain more to me | |
