12-18-2021, 15:49 | #3 (permalink) |
Insane Poster Join Date: Jun 2006
Member: 293267 Status: Offline Thanks Meter: 14 | Card found : 85395A8F , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v1121431 Ok! Update configuration ... Update Ok! Load IDBase v1121431 Ok! Operation : HW Report [ v2.28 ] HWreport : Mode : UFS 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM60) MODE : BOOTROM PORT : 60 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : EBBEB507EEA0532562B0CF8E06A7AD56 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 548D3310BCAA4B5ACBB72A1767CD41C4EC428706565CFB19BB 2D955FD8765DEA BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : FF : Look for EMI BROM : FF : EMI not found BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_MT6785.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : SYNC char NOT received! Info : LEGACY : HW reporting feature unavailable for current device! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Done! Elapsed: 00:00:52 Operation : HW Report [ v2.28 ] HWreport : Mode : UFS 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM60) MODE : BOOTROM PORT : 60 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : 599714AE462EC077A18CCD30C6258F2E BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 5D8C3DA317757906EFC174240617602DD377EB01F23D010C3F 24149020898E36 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_MT6785.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k85v1_64.bin EMI : CNT : 0004 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: CE014B4D3856393030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V9001JM-B81 IFW : 0100 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 00350036006300310036003600370063 REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 42763FEF9069206D683AB1E033A89DDB DA : USB : HIGH-SPEED Boot done! Memory Info : CID : KM8V9001JM-B813 EXT_CSD Info : [UFS] Device Desc: [UFS] String Desc: Serial Number INDEX 2, LENGTH 24 [UFS] Serial Number: 003500360063003100360036003700630036003700320035 [UFS] life cycle check, pre_eol_info=1, life_time_est_a=1, life_time_est_b=1 [UFS] vendor id : 0x1ce [UFS] ufs id : KM8V9001JM-B813 [UFS] ufs fwver: 0100 [UFS] dev_quirk = 0x0 [UFS] Custom force provison=0, TW size=-1GB, TW no red=1, HPB size=-1GB [UFS] info: number of active LU: 3, check OK. [UFS] info: number of Boot LU: 2, check OK. [UFS] info: LU Configuration Check OK. Bootable UFS [UFS] info: Boot LU Configuration Check OK. Active Boot LU: LU0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] info: HS-G3-2 Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY NOT set! [State : CLEAN : USABLE] STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:39 |
