07-06-2018, 12:00 | #1 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | vivo y83 pattern lock remove problem Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 59 ] Sync... Inital Boot Ok! BB_CPU_PID : 0766 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0xE5000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : Unknown Mode! Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:23 Reconnect Power/Cable! how to remove lock please help me |
07-06-2018, 12:10 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 47
Member: 135671 Status: Offline Thanks Meter: 45 | The same ViVo Y85 CPU MT6765 With details Model : vivo 1726 Version : 8.1.0 Hardware : mt6765 Baseband : MOLY.LR12A.R2.MP.V23.P45 CPU : arm64-v8a |
The Following User Says Thank You to nctrung_vn For This Useful Post: |
07-06-2018, 12:53 | #4 (permalink) |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | bro not work with cm2 mtk v2.00 r4 Operation : Identify [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM59) MODE : BOOTROM PORT : 59 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+SEL BROM : BOOTROM MODE : Vivo : V5 | Manual : Disabled BROM : SLA BROM : Selected Auth/Cert not accepted by device! Check previous message for more info! Reconnect Power/Cable! |
