12-07-2006, 21:00 | #1 (permalink) |
Registered User Join Date: Jun 2006 Location: Latvia Daugavpils
Member: 288627 Status: Offline Thanks Meter: 0 | VK530 unlock problem using infinity box COM4 selected Phone must be POWERED-ON ! Voxtel V500óýá± Err: Phone not powered or bad connection Err: operation not finished properly Finished Help, plzzz |
12-07-2006, 22:19 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, wrong text in log window: it was just small not important bug, it don't affect to unlock process. Anyway I'll double check and let you know some time later but pls, try to connect phone again and try to repeat unlock process. |
12-09-2006, 16:29 | #6 (permalink) |
No Life Poster Join Date: Feb 2004 Location: egypt Age: 51
Member: 52847 Status: Offline Thanks Meter: 73 | hi vk5xx cant unlock with infinity box i test vk530 & vk570 ... COM5 selected Phone must be POWERED-ON ! Voxtel V500©|o™ Err: Phone not powered or bad connection Err: operation not finished properly Finished cable vk207i work with fb2 tested ...thanks |
12-11-2006, 11:43 | #8 (permalink) |
Member: 288627 Status: Offline Thanks Meter: 0 | now such result: COM4 selected Phone must be POWERED-ON ! Connecting, wait... Err: can't read software version Err: can't read hardware version Err: Phone not powered or bad connection Err: operation not finished properly Finished |
12-11-2006, 13:15 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, be sure that you use correct cable and com port selected correctly. I tested this version before release on my own phone several times and it was no any problems (btw, tested with previous version too, but to remove small bugs new version was released). Phone must be powered ON and backlight should be On. also, check cable. maybe it's bad cable. |
12-18-2006, 11:14 | #11 (permalink) |
Freak Poster Join Date: Mar 2003 Location: LAHORE PAKISTAN.
Member: 24920 Status: Offline Thanks Meter: 11 | hi sir after showing some bad text set is unlocked , but after that there is no signals on the set .( no service ) whats the remedy....................... regards mahmood shad pakistan |
01-31-2007, 20:09 | #13 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Prussia
Member: 7844 Status: Offline Thanks Meter: 182 | succesfully unlocked vk530 using infinity & vk 207i cable from FB . used left rj45 connector and clicked on SCAN used com-27 VCPO COM27 selected Phone must be POWERED-ON ! Connecting, wait... software version: VK530AUK_NH2.09R hardware version: VK530_01.00 Phone connected. Working... SIM Lock: Deactivated EXT Lock: Deactivated Vodafone Lock: Deactivated N/A-1 Lock: Deactivated N/A-2 Lock: Deactivated N/A-3 Lock: Deactivated Power-Off phone now by Power button (don't remove battery) Finished |
how to use infinity box and infinity apf box plus | wahablepirate | Infinity-Box | 10 | 06-14-2012 17:27 |
Vodafone 228 Unlocked OK by Infinity box using Pinfinder | MDK23 | Infinity-Box | 6 | 01-10-2009 18:04 |
LG-225 how to unlock using INFINITY BOX? | rolly_van | Infinity-Box | 1 | 09-09-2008 15:00 |
c139 trackfone unlock with no test point , using infinity box | etimoult | Infinity-Box | 3 | 06-07-2008 19:11 |
c139 trackfone unlock with no test point , using infinity box | etimoult | Infinity-Box | 3 | 06-06-2008 06:45 |
