08-25-2020, 11:06 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: United Kingdom
Member: 670771 Status: Offline Thanks Meter: 9 | VkMob01 software not working would you kindly help me with this vk mobile software as its not working VkMob01 software its install all package from main software but when click run nothing happens cheeked from main folder something not opening Infinity-Box team please need help |
08-25-2020, 12:32 | #2 (permalink) | |
What is your dongle S/N ? Do you see any error message or software is completely silent ? What is your OS ? Do you have any antivirus software running ? | |
08-25-2020, 12:57 | #3 (permalink) | |
Member: 670771 Status: Offline Thanks Meter: 9 | here is details Quote:
completely silent using last shel v1.47 S/N: 0E87:0134:00 no error using other software work fine like VkMobile02s | |
08-25-2020, 13:04 | #4 (permalink) | |
Do you have any antivirus software running ? It should be no problem with you dongle and with this software. If you can run other old software modules well but only VkMob01 has a problem it means something wrong with VkMob01 files. Try to re-install whole package to another path, f.e. to c:/InfinityBox1/ and try to run VkMob01 again. Also it may be a result of your antivirus. Try to disable it. result ? | |
08-25-2020, 13:19 | #5 (permalink) | |
Member: 670771 Status: Offline Thanks Meter: 9 | Quote:
im using w7 64b no anti virus path, f.e. to c:/InfinityBox1/ will check that and let you know | |
08-25-2020, 17:25 | #9 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Probably problem reason is: software is quite old. I can run well under XP (just tested) but newer OS may block this exe. If you really want to run it you can install XP VM and try |
