vodafone 226 unlock 100% today i have unlocked Vodafone226 sagem with infinity box (PANA 01 v1.48) thankyou INFINITY BOX INFINITY BOX it`s good support:D:D |
sir what is the pinout of vodafone 226...pls give me urgent |
The same as my220x, 220v, Vodafone 226, 1 gnd, 7- 8 rx tx. |
Pls post me the lock code of vodafone 226 urgent. |
1: Gnd 9: Box Rx/Phone Tx (RJ45 pin 3) 10: Box Tx/Phone Rx (RJ45 pin 2) 16: Gnd |
COM4 [VCP0] selected Device: Vodafone-226 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IS 141207_1106 EBI_IS_141207_1106 Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Program Files\InfinityBox\Pana01\Vodafone-226_eeprom-sta_20080906-185719.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: D:\Program Files\InfinityBox\Pana01\Vodafone-226_eeprom-sec_20080906-185721.B1E.bin reading [eeprom-complete]... file saved: D:\Program Files\InfinityBox\Pana01\Vodafone-226_eeprom-complete_20080906-185723.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 42 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
bro wat's da cable??????????????????? |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) http://www.infinity-box.biz/download...shell_v112.jpg Here is information how to build your own cable: http://forum.gsmhosting.com/vbb/showthread.php?t=342807 |
