06-11-2008, 15:12 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | vodafone 226 unlock 100% with infinity box (PANA 01 v1.48) thankyou INFINITY BOX INFINITY BOX it`s good support |
09-06-2008, 14:06 | #7 (permalink) |
Insane Poster Join Date: Aug 2005 Location: BANGLADESH Age: 50
Member: 170700 Status: Offline Thanks Meter: 8 | COM4 [VCP0] selected Device: Vodafone-226 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IS 141207_1106 EBI_IS_141207_1106 Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Program Files\InfinityBox\Pana01\Vodafone-226_eeprom-sta_20080906-185719.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: D:\Program Files\InfinityBox\Pana01\Vodafone-226_eeprom-sec_20080906-185721.B1E.bin reading [eeprom-complete]... file saved: D:\Program Files\InfinityBox\Pana01\Vodafone-226_eeprom-complete_20080906-185723.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 42 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
The Following User Says Thank You to mohin_ic For This Useful Post: |
09-07-2008, 23:31 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
12-18-2008, 09:03 | #10 (permalink) |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is information how to build your own cable: http://forum.gsmhosting.com/vbb/showthread.php?t=342807 |
The Following User Says Thank You to zinoubinabil For This Useful Post: |
Vodafone 226 Unlock clip | jivkobg | The Market Feed Back | 61 | 02-02-2009 00:12 |
Vodafone 226 unlock 100% ok | maheshsaiganesh | Infinity-Box | 2 | 05-01-2008 18:43 |
vodafone 226 unlock code | mobile20 | ARM9 BASED M62 / M62+ | 7 | 03-27-2008 16:23 |
VODAFONE 226! unlock by IMEI ? | Supermen! | MT-BOX | 2 | 11-10-2007 17:30 |
Vodafone 226 unlock???? | roverboc | Various | 0 | 10-01-2007 07:30 |
