08-08-2008, 18:38 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: india Age: 47
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | vodafone 226fm phone code ? need help infinity teem i have vodafone 226fm phone unlock done but still phone code ? when i put 12345678,00000000,1234,1122 phone give me error incorrect code plz help me for this error |
08-08-2008, 22:56 | #2 (permalink) |
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | COM40 [Serial2] selected Device: Vodafone-226FM Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EDI_IF EDI_IF_040108_1352 040108_1352 Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-sta_20080809-032339.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-sec_20080809-032353.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20080809-032359.B1E.bin reading additional data... done backup critical area Done Check memory... current status: #2, already unlocked already done (mode-0), operation aborted Check memory Failed Finished, Remove/Install battery now ! Time used: 86 sec |
08-09-2008, 04:20 | #6 (permalink) |
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | (1) go to flash menu in infinity pana01.exe (2) silect Eeprom from support in Sagem / repair/ folder download this file Vodafone-V226FM_EDI_IE_211207_1322_lock_area_original.B1E.b in Vodafone-V226FM_EDI_IF_040108_1352_lock_area_original.B1E.b in (3) load Eeprom if your phone v. is 4.18 silect this file Vodafone-V226FM_EDI_IF_040108_1352_lock_area_original.B1E.b in (4) write & save og files (5) now phone is locked (6) go to service menu silect unlock method-1 press unlock & enjoy COM40 [Serial2] selected Device: Vodafone-226FM Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EDI_IF EDI_IF_040108_1352 040108_1352 Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-sta_20080809-083527.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-sec_20080809-083530.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20080809-083535.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 40 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
The Following User Says Thank You to rajtelecom For This Useful Post: |
09-05-2008, 13:16 | #7 (permalink) |
Freak Poster Join Date: Jan 2007 Location: MANGLORE-INDIA
Member: 422855 Status: Offline Sonork: 100.1601859 Thanks Meter: 40 | Hi Rajtelecom...i Have Also Same Problem Coming When I Unlocking Voafone 226fm.... Now I Will Try As Your Method..and Give You Reply Soon.... Thanks Ya... |
09-05-2008, 13:51 | #8 (permalink) |
Member: 422855 Status: Offline Sonork: 100.1601859 Thanks Meter: 40 | Hello Rajtelecom... I Tried As Your Method... After Unlocking When I Entering The Unlock Code 12345678.but In Display Number Not Coming..ANY SOLLUTION |
09-11-2008, 11:16 | #9 (permalink) |
Member: 422855 Status: Offline Sonork: 100.1601859 Thanks Meter: 40 | Hi now phone(vodafone 226 fm) is showing phone locked.. If i enter the number its not accepting... Then also still in phone locked... Pls give me any sollution i am waiting for your reply..... |
Need help infinity teem | ali_imran | Infinity-Box | 1 | 02-18-2009 17:09 |
vodafone 226fm phone code ? unlock success | rajtelecom | Infinity-Box | 18 | 02-01-2009 15:49 |
need help infinity teem | rajtelecom | Infinity-Box | 3 | 12-10-2008 18:30 |
Vodafone-226FM phone code not open | sayfulalam | Infinity-Box | 3 | 07-30-2008 14:38 |
need help infinity teem | rajtelecom | Infinity-Box | 1 | 10-30-2007 15:13 |
