09-07-2010, 10:47 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Kosova
Member: 87568 Status: Offline Thanks Meter: 101 | Vodafone 250 unlock problem COM6 [VCP0] selected module v3.57 Device: Vodafone-250 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6C86:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 00390000/00068000 TCL-ID identification version: 26E provider: 250X-2AVDRS1 customization: CW26CM61 customization: XW26CM61 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 00390000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XW26CM61 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 0000F89125A5BE flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-250_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W0 8_36_SP1_V28_F1__system_log__00000000_20100907-112718.B0X.bin Finished, time used: 2 min 2 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! After phone just power on and off. Now i make "Repair security area" and phone is ok, but still locked. Please have any other solution to unlock? |
09-08-2010, 18:13 | #2 (permalink) |
No Life Poster Join Date: Sep 2009 Location: K'dua , 3rd Fl Main K'si St GH
Member: 1123079 Status: Offline Sonork: 100.1586814 Thanks Meter: 439 | Please try and use search here in infinity section. Download flash file from support and flash phone again. then do SP UNLOCK and write IMEI (Make sure you key in the number from the back of phone or use *#06#) Hope this helps you and good luck. |
09-08-2010, 20:16 | #3 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Ghana Age: 39
Member: 153893 Status: Offline Thanks Meter: 266 | Bro this solution is not working,pls infinity team try to do something about this cus is only works on vodafone 150 |
The Following User Says Thank You to godwin For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
