Old 12-12-2010, 15:03   #1 (permalink)
Member: 716133
Thanks Meter: 38
vodafone 541 flash file
hello i have 541 flash file please convert infinity box
RapidShare AG, Cham, Switzerland
The Following User Says Thank You to newerno For This Useful Post:
Old 12-12-2010, 20:04   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
Thank you very much !
We will check, prepare and upload files in support area as soon as possible.
Old 12-12-2010, 20:05   #3 (permalink)
Member: 716133
Thanks Meter: 38
i waiting maybe insert today?
Old 12-12-2010, 20:08   #4 (permalink)
Member: 1043909
If it's a new file then it will be need to make software update as well, I can not promise that it will be done today.
Old 12-12-2010, 20:18   #5 (permalink)
Member: 716133
Thanks Meter: 38
i understen my phone dead i looking flash is file thanks infinity box best
Old 12-12-2010, 20:28   #6 (permalink)
Member: 1043909
I am sure that you can repair phone with help of flash files from support area.
Did you tried to flash your phone with files from support area ?
Old 12-12-2010, 20:34   #7 (permalink)
Member: 716133
Thanks Meter: 38
i get 2 flash file from support i write flash my phone no swish on brol maybe is flash file good my provider 708x-2hvdgb1
Old 12-12-2010, 20:44   #8 (permalink)
Member: 1043909
1. check your phone battery voltage !!!! It may be that battery is almost empty !!!
2. post here operation log for flashing operation so we will check it (but first CHECK BATTERY !!!!!)
Old 12-12-2010, 20:55   #9 (permalink)
Member: 716133
Thanks Meter: 38
battery 2 sticks i cheking alcatel phone and please waite write log after flash
Old 12-12-2010, 21:01   #10 (permalink)
Member: 716133
Thanks Meter: 38
COM4 [VCP0] selected
COM4 not available
Abort operation ?
COM4 not available
Abort operation ?
module v3.67
Device: Vodafone-541
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
708X-2FVDGB1-17B_XN17FC75_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-09-10_En_Fr_Es_It_De_Vodafone-541.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:9A03:A00D
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22302200:09EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.A9E24 EEA.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: A9E24EEA
rom info ver: 07
sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8
code offset: 00020000
ffs offset/size [01]: 01800000/00800000
TCL-ID identification
version: 17B
provider: 708X-2HVDPT1
customization: CN17FG72
customization: XN17FG72
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 01800000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is valid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: disabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35908103344418
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
usb bootloader (file) is present: 00020000
rom info relocation detected
startup code area #1 check...
startup code area #1 calculation...
startup code area #1 fixed
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_A9E24EEA_E8F450A0_20101212-195434.B0X.bin
Area: Firmware
Write: Firmware
sec info (fast) detection...
security area (sec info, cust) calculation...
error: security area (sec info, cust) header is invalid
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
identification header detected
relocation table detected
name table[00] #9000000 detected
customization: SN17B140
warning: customization name is unknown
name table[01] #7000000 detected
customization: CN17FC75
customization name adjusted
customization detected: CN17FC75
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
done
done
Write Done
====> Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_A9E24EEA_E8F450A0_20101212-195839.B0X.bin
Finished, time used: 5 min 15 sec
Remove/Install battery now !
Old 12-12-2010, 21:56   #11 (permalink)
Member: 1043909
Download and install latest MModule from Infinity-Box support area and repeat flash operation.
What is the results ?
Old 12-12-2010, 22:04   #12 (permalink)
Member: 716133
Thanks Meter: 38
i downlod and instal mmodule and flash again?
Old 12-12-2010, 22:15   #13 (permalink)
Member: 1043909
1. Download latest MModule from Infinity-Box support area
2. Install latest MModule
3. Flash phone again with latest MModule software
Old 12-12-2010, 22:16   #14 (permalink)
Member: 716133
Thanks Meter: 38
phone no workin
module v3.70
Action: write flash
write: Firmware
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
TCL-ID detection...
device-id: A9E24EEA
rom info ver: 07
version: 17B
provider: 708X-2FVDGB1
customization: XN17FC75
TCL-ID is present
area1 is valid
area2 is invalid
area3 is valid
area4 is invalid
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
====> Write ...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_A9E24EEA_E8F450A0_20101212-211147.B0X.bin
Area: Firmware
Write: Firmware
done
done
done
Write Done
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_A9E24EEA_E8F450A0_20101212-211416.B0X.bin
Finished, time used: 3 min 39 sec
Old 12-12-2010, 22:34   #15 (permalink)
Member: 1043909
Hello,
Try to flash phone with another flash files.
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
how can we use *.scr files to unlock shadow77 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-27-1999 03:13
Page generated in 0.66348 seconds with 9 queries
