12-26-2009, 08:02 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: romania Age: 40
Member: 631660 Status: Offline Thanks Meter: 139 | vodafone 541 relock after power off module v3.00 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7103:A00D status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: E:\Program Files\InfinityBox\MModule\backup_security\id.355A7 7BB.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_064A906B].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 355A77BB rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, 6B904A06 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17C provider: 708X-2FVDES1 customization: CN17FE82 customization: XN17FE82 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FB75 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FB75 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: E:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_355A77BB_064A906B_20 091226-084939.B0X.bin Finished, time used: 4 min 7 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! all ok till here....when i put in cutomer sim ...phone is locked again on all networks...after all flashes from supoort found one which is working no more dead phone buttt lock problem....plz infinity can you help me ???????? |
12-26-2009, 08:36 | #3 (permalink) | |
Member: 631660 Status: Offline Thanks Meter: 139 | Quote:
read think before posting vodafone 541 is alcatel 708x my first problem was that flash was not supported or something found working flash on support but phone auto relock after change sim (phone was killed by sunday unlocker and spiderman crack so no good back-up) solution to all vodafone 541 if only error at unlock:write fw-> unlock ->repair security area-> unlock mine worked only this way...thanks infinity team for this great dongle | |
12-26-2009, 09:29 | #4 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | ah ... sorry for that just mixed two threads Br Faisal_Computer |
The Following User Says Thank You to Faisal_Computer For This Useful Post: |
Vodafone 541 dead after flash | Farshedjon | Infinity-Box | 4 | 06-14-2010 13:14 |
Vodafone 541 Uk after unlock touch problem????? | Unlocker AL | Infinity-Box | 1 | 03-05-2010 16:23 |
6300 auto on after power off | jamohaki | Nokia Hardware & Hardware Repair | 3 | 10-07-2009 04:30 |
j220i relock after turn off and turn on | thienchi | Sony Ericsson | 6 | 09-18-2008 12:29 |
UNLOCK NCK, after power OFF all 4 LOCK are active ????!!!!! | ptkrf | Old Ericsson Phones & Sony Phones | 0 | 10-27-1999 21:50 |
