Old 03-02-2015, 13:36   #1 (permalink)
Macie provider's Avatar
Member: 1652212
Thanks Meter: 73
Vodafone smart tab iii 7 mt6589 problem...
VODAFONE SMART TAB III 7 MT6589__LENOVO__Vodafone_Smart_Tab_III_7__IdeaTabA 3000-H__A3000__ALPS.JB2.MP.V1.9__Android_4.2.2__2013081 3_211911
Tablet was asking for privacy lock, tryed to remove withou sucess, so i
1-back up flash
2-format with safe mode without sucess
3-format with *0* ok
4-phone stuck on logo and ask for *DL MODE* but when i try to fix cant fix
5- try to flash with back up, always same error;
Chinese Miracle II [MTK module] v 1.13
Load File
File_Info : lenovo89_tb_vf_a_jb2
FileVersion : MT6589
Load File Ok
Operation : Flash [ v1.13 ]
======= Flash
Files set for flashing :
[ MCU ] : VODAFONE SMART TAB III 7 MT6589__LENOVO__Vodafone_Smart_Tab_III_7__IdeaTabA 3000-H__A3000__ALPS.JB2.MP.V1.9__Android_4.2.2__2013081 3_211911.ispff
Wait for phone...
Phone found! [ 17 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6583
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6583|6589_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 484A019065324741A20102045F80D660
DA Stat : v3.2 on BBID : 0x86
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : e2GA
[eMMC] : FLASH_CID : 90014A4841473265040201A260D6805F
[eMMC] : FLASH_LEN : 0x00000003AB800000
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ISPFF ID : 6589
TARGET ID : 6583
Flash pre-erase enabled
Erase Flash now ...
Flash pre-erase done
Write Flash now ...
Init Ok , Sending blocks ...
Write failed
Flash Error!
Check Cable, Battery , try again
Operation Failed
Elapsed: 00:01:53
Reconnect Power/Cable!
the phone doesnt have usb conection either battery problem, need help
br
Macie@Provider
Old 03-02-2015, 13:40   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hi. I want see to "Remove Privacy" and "Fix DL" logs. Very interest.
Old 03-02-2015, 13:59   #3 (permalink)
Member: 1652212
Thanks Meter: 73
Wait for phone...
Phone found! [ 28 ]
Sync...
Boot Info :
BB_CPU_ID : 6583
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Checking data ...
Privacy Lock not set!
Done!
Elapsed: 00:00:12
and
Operation : Fix DL Errors [ v1.12 ]
Wait for phone...
Phone found! [ 28 ]
Sync...
Boot Info :
BB_CPU_ID : 6583
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:30
Old 03-02-2015, 14:14   #4 (permalink)
JayDi's Avatar
Member: 462970
@Macie provider , this phone have privacy lock enabled?
I need to check the dump, but 16GiB is very big size. Will send you instructions and some things to make some tests after few hours in PM.
The Following User Says Thank You to JayDi For This Useful Post:
Old 03-02-2015, 14:58   #5 (permalink)
Member: 1652212
Thanks Meter: 73
Its not phone lock, becouse phone was working fine without sim and its not network locked im sure, i already tryed to format manually with adb etc...didnt work. so my conclusion *privacy lock*
info: when i try to flash with *FLASH ERASE* checked stop on 1% unchecked 3%
br
Macie@Provider
Old 03-02-2015, 16:14   #6 (permalink)
JayDi's Avatar
Member: 462970
Hope, you charged battery fully
Just tested 2x 6589 samples to make sure about all is working Okay.
Privacy Lock - should ask for Privacy Password. If it is not Privacy ( because not seen yet it on 6589 ) - that can mean some problrems with flash IC , but anyway, need check all before.
Old 03-03-2015, 16:57   #7 (permalink)
Member: 1652212
Thanks Meter: 73
UP UP, can i have at last any flasher to flash using my backup to put the phone in the way was before?
Old 03-03-2015, 17:05   #8 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,405
most probably battery is not full charge use external supply for battery charge and charge battery atleast 1 or 2 hours than try to flash one more thing when battery charge it cant coneect wth tablet
Old 03-03-2015, 17:05   #9 (permalink)
JayDi's Avatar
Member: 462970
Then, you not make any factory FW backup before?
Old 03-03-2015, 17:18   #10 (permalink)
Member: 1652212
Thanks Meter: 73
i can upload a pic with baterry 100% if needed, i said that the battery is full charged. why? becouse when i try to repair DL MODE phone turn off completly, and when i plug charge only charge until i power on.
Old 03-03-2015, 17:24   #11 (permalink)
Member: 1652212
Thanks Meter: 73
didnt acepted to make when tryed to, only this full backup, my question: is there any one with this factory FW backup ?
Old 03-06-2015, 10:25   #12 (permalink)
Member: 1652212
Thanks Meter: 73
Dear JayDi Still nothing from you?
br
Macie@Provider
Old 03-06-2015, 10:52   #13 (permalink)
Member: 851193
Sonork: 100.1615313
Thanks Meter: 348
@jaydi
can you activate my infinity dongle ?so I can make test and upload logs for latest phones?
check you PM did sent 2 times request for my infinity dongle s/n
thanks
Old 03-06-2015, 14:28   #14 (permalink)
Member: 1652212
Thanks Meter: 73
Originally Posted by kariakala View Post
@jaydi
thanks
no need to PM no body, read...http://forum.gsmhosting.com/vbb/f296...iatek-1827134/
Old 03-07-2015, 03:35   #15 (permalink)
Member: 851193
Sonork: 100.1615313
Thanks Meter: 348
@jaydi
told me to activate free my infinity dongle for latest mtk /spd phone software) for infinity
that's is why I send him pm
Page generated in 0.28324 seconds with 9 queries
