04-08-2019, 16:27 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Africa
Member: 1917743 Status: Offline Thanks Meter: 36 | Vodafone VFD 301 PreLoader : NOT Active [ Erased ] Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 7001004545344544340109CDC079941F Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBC000000 DRAM_INIT_REQ_FAILED Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! Last edited by kalinichenko; 04-08-2019 at 16:29. Reason: typo |
04-09-2019, 08:18 | #3 (permalink) | ||
Member: 1917743 Status: Offline Thanks Meter: 36 | Identify log Quote:
Log Quote:
04-10-2019, 15:54 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Check both logs. Identify and flashing. Check listed preloaders FLASH'ids against installed in device. It changed by someone and that is reason why it not work. Since it is some variant of Alcatel? with OTP - then you can't install other eMCP, instead listed ones. |
04-11-2019, 00:10 | #7 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote: b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
04-11-2019, 00:33 | #8 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | And here is attached correct (original) preloader (and scatter) for V301-2AVDGH1 ... after flashing any other PID rom, flash just preloader after. Phone should be alive. (or just put attached preloader in that posted rom and flash all) b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
04-16-2019, 03:18 | #10 (permalink) | |
First try ... reset to factory from phone recovery if not help, try something a bit strange - check here on in alcatel section, about V300, there are several flash files, try to write only userdata from it. b.r. Alex
