09-12-2017, 09:40 | #1 (permalink) | ||
No Life Poster Join Date: May 2011 Location: ..:Inside UR Brain:.. Age: 34
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | Lenovo k8 note after reset frp dl image fail error... FRP Reset logs Quote:
i tried Fix Dl function ..... Quote:
But still the phone is stuck in DL Image fail error. The phone was working fine before resetting Frp. Now im stuck with this problem .. There is no firmware available over the net. Can anyone please help me regarding this issue. | ||
The Following User Says Thank You to shaikh_shoeb50 For This Useful Post: |
09-12-2017, 13:23 | #2 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: MUMBAI-METRO Age: 37
Member: 1800009 Status: Offline Sonork: 100.1654307 Thanks Meter: 806 | Hi Quote:
read file with cm2 in this condition after read use sptool to solve dl error select file tick on only cache with dl checksum | |
The Following User Says Thank You to mobite For This Useful Post: |
10-09-2017, 22:16 | #7 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | It is not that much difficult. Just read all info by cm2.. get project id and download corresponding firmware. Flash it and solved. All you need is correct project id to download correct firmware. |
12-23-2017, 18:55 | #8 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Lake Mary (Orlando)
Member: 1016569 Status: Offline Thanks Meter: 229 | Quote:
Use SP tool instead to CM2 in case...... | |
