03-29-2008, 21:55 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: EGYPT & oman Age: 39
Member: 63774 Status: Offline Sonork: 100.88137 Thanks Meter: 134 | w220 dead give me probaly wrong model selected continue anywa? COM13 [Serial2] selected Device: Motorola W220 "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... 812500 Set baud done Check hardware... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb version sw: version sw: Check hardware done Read data... reading Motorola W220_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\backup_Motorola W220_eeprom_calibration-1_20080329-224529.6AE.bin reading Motorola W220_ffs... file saved: D:\Program Files\InfinityBox\HModule\backup_Motorola W220_ffs_20080329-224553.6AE.bin Read data done Check data... warning: Probably wrong model selected, Do you want to continue ? model selection confirmed by user Check data done Writing... Area: Firmware flash: 89886400010001:89886400000000 Write: Firmware Area: Flex flash: 89886400000000:89886400000000 Write: Flex Area: Language Pack flash: 89886400000000:89886400000000 Write: Language Pack Area: Images flash: 89886400000000:89886400000000 Write: Images Area: Melody flash: 89886400000000:89886400000000 Write: Melody Writing done Finished, time used: 320 sec Remove/Install battery now ! |
03-30-2008, 14:27 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Use anoyther flash files sets for flashing, use latest firmware version. How to know what files to use ? You have a flash files description in DOCUMENTATION folder and in support area files divided by versions. |
03-30-2008, 21:05 | #5 (permalink) |
Member: 63774 Status: Offline Sonork: 100.88137 Thanks Meter: 134 | i flash phone with w220_Main_SCY-7-1270-000.6AM.bin w220_Flex_SCY-7-0460-239.6AF.bin w220_LP_SCY-0-0430-121.6AP.bin w220_Melody_SCY-7-0270-015.6AG.bin w220_Melody_SCY-7-0270-015.6AG.bin and also with some other flashes from description in DOCUMENTATION |
03-30-2008, 21:28 | #7 (permalink) |
Member: 63774 Status: Offline Sonork: 100.88137 Thanks Meter: 134 | COM13 [Serial2] selected Device: Motorola W220 "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... 812500 Set baud done Check hardware... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb version sw: version sw: Check hardware done Read data... reading Motorola W220_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\backup_Motorola W220_eeprom_calibration-1_20080330-220526.6AE.bin reading Motorola W220_ffs... file saved: D:\Program Files\InfinityBox\HModule\backup_Motorola W220_ffs_20080330-220547.6AE.bin Read data done Check data... warning: Probably wrong model selected, Do you want to continue ? model selection confirmed by user Check data done Writing... Area: Firmware flash: 89886400010001:89886400000000 Write: Firmware Area: Flex flash: 89886400000000:89886400000000 Write: Flex Area: Language Pack flash: 89886400000000:89886400000000 Write: Language Pack Area: Images flash: 89886400000000:89886400000000 Write: Images Area: Melody flash: 89886400000000:89886400000000 Write: Melody Writing done Finished, time used: 273 sec Remove/Install battery now ! |
03-30-2008, 22:10 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @Tamer_Elhosary http://www./showpo...81&postcount=6 |
03-31-2008, 16:33 | #12 (permalink) |
Member: 63774 Status: Offline Sonork: 100.88137 Thanks Meter: 134 | ok bro i flash phone with all flashes from support and also flashes with names main_lp_flex_images_melody *w220_SCA-7_1220_0390-013_0420-083_0280-023_0240-006_main_lp_flex_images_melody.6AM.bin *w220_SCA-7-109A_0300-013_0310-084_0210-029_0210-008_main_lp_flex_images_melody_Telmex.6AM.bin * |
03-31-2008, 22:17 | #13 (permalink) |
No Life Poster Join Date: Jul 2005 Location: egypt Age: 43
Member: 158471 Status: Offline Sonork: 100.1588029 Thanks Meter: 120 | i flashed this phone to change lang to arabic and useing this files (1)W220_Main_7-1130-000_2006-Sep-14.6AM.bin (2)W220_Flex_0330-013_T678FC_2V25_V1.6AF.bin (3)W220_LP_0310-008_T678AW_2V25_V1_En_Fr_Arabic_Farsi_Urdu.6AP.bin (5)W220_Images_0220-004_T678AP_2V25_V1.6AG.bin (6)W220_Melody_0210-004_T678AP_2V25_V1.6AG.bin |
03-31-2008, 23:48 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @Tamer_Elhosary @el-safwa I don't understand what is the results @Tamer_Elhosary if w220 can't power-on but you are sure that phone hardware is Ok and if you don't know what was original firmware version there is only one way: try to use different flash files sets and see results after each flash process (I have repeated this advice already several times, can't understand what is the problem to read and understand it). |
W220 dead after flashing. | Mr GsM | Infinity-Box | 5 | 03-24-2009 13:46 |
w220 dead while preparing phone | ryaz1993. | Infinity-Box | 2 | 03-07-2007 11:49 |
W220 dead after flashing. Help!! | cqln | Motorola P2k | 1 | 02-22-2007 21:58 |
w220 dead after flash | .:KHALIFA:. | Infinity-Box | 10 | 02-04-2007 19:21 |
W220 dead during prepare process | NeTRaW | Infinity-Box | 2 | 01-19-2007 17:41 |
