Old 12-21-2009, 16:27   #1 (permalink)
Member: 613221
Thanks Meter: 26
W220 dead. Please help me Support Team!!!!
Hi, I was trying to unlock a Motorola W220 locked to TUYO Provider. Here is first log:
COM5 [VCP0] selected
module v1.34
Device: Motorola-W220
"advanced chip detection" active
Action: unlock
Checking data, wait...
Boot ...
Press Power button now !
loading...
Boot done
Check connection ...
Check connection done
Set baud ...
812500
Set baud done
Check hardware ...
flash: 208810FFFFFFFF:20881000000000
flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb
software version: 235C-000
software version: SCU-9-
Check hardware done
Read data ...
reading Motorola-W220_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Motorola-W220_eeprom_calibration-1_20091219-133048.6AE.bin
Read data done
Check data ...
warning: Probably wrong model selected,
Do you want to continue ?
model selection confirmed by user
error: not locked or unknown eeprom
Check data done
Write ...
.error: required data not found or unknown eeprom structure
Write fail
error: operation failed
Finished, time used: 14 sec
Remove/Install battery now !
I read in the forum that I needed to flash with a repair eeprom so I did, I flashed with this eeprom: W220_repair_eeprom_10.6AE.bin, here is operation log:
module v1.34
Action: flash write
Skip: Firmware
Skip: Flex
Skip: Language Pack
Skip: FFS/File system
Skip: Images
Skip: Melody
Write: Eeprom
Boot ...
loading...
Boot done
Set baud ...
812500
Set baud done
Check hardware ...
Check hardware done
Read data ...
Read data done
Check data ...
Check data done
Write ...
Area: Eeprom
Write: Eeprom
Write done
Finished, time used: 25 sec
Everything went smoothly, but now phone wont power on, It wont boot, It wont connect to the sofware. I charged the battery full with another phone, tried with different cables, tried with other boxes but it just won't work. Phone was fully functional before I flashed with eeprom so it is not hardware problem. Please help me.
Old 12-21-2009, 17:05   #2 (permalink)
Member: 46350
Thanks Meter: 885
Try to flash with full flash ..not only eeprom
Old 12-21-2009, 17:08   #3 (permalink)
Member: 613221
Thanks Meter: 26
Thank you for answering, but did you at least read my whole post?
The phone won't connect to the software, after I flashed with that eeprom, phone is not responding.
Old 12-21-2009, 17:45   #4 (permalink)
Member: 540878
Thanks Meter: 910
try to use RPS than battery.................
Old 12-21-2009, 18:00   #5 (permalink)
Member: 613221
Thanks Meter: 26
RPS???? what is that??
Old 12-21-2009, 19:56   #6 (permalink)
Nadjombe's Avatar
Member: 185608
Thanks Meter: 593
Try to use something what match with 235C and format ffs.
Old 12-21-2009, 21:00   #7 (permalink)
Member: 613221
Thanks Meter: 26
Oh my G O D, looks like no one is reading my entire post, the phone wont connect to software people. The phone was working excellent before I flashed the eeprom, after flashing eeprom phone won't turn on and won't connect.
Old 12-21-2009, 21:00   #8 (permalink)
Member: 613221
Thanks Meter: 26
Where is support team anyways???
Old 12-21-2009, 22:45   #9 (permalink)
Member: 130995
Thanks Meter: 35,228
As ordinary, I was sleeping, it's my ordinary life style.
Old 12-21-2009, 22:46   #10 (permalink)
Member: 130995
It can not be true that after flashing phone with repair eeprom phone can not boot any more.
At least I do not have any kind of this examples.
You need to double check your cable, check all wires carefully. Try to use another cable.
After you will be able to boot phone you just need to make "Repair" operation.
Old 12-22-2009, 01:57   #11 (permalink)
arx
Member: 134843
Sonork: none
Thanks Meter: 81
got same prob here my friend...i have w220 already unlocked...i just need to flash it to work with 900/1800mhz....i notice this error: warning: Probably wrong model selected,
Do you want to continue ? i just press yes...and flashing went smooth...after flashing, the phone was dead...i thought wrong flashfile..but when i reflash it again, THE PHONE WON'T CONNECT ANYMORE....i did everything i can..use other t191 cable, even direct to its pinout, etc....
infinity team, please try this prob, i hope you can figure it all out...
thanks
Old 12-22-2009, 02:02   #12 (permalink)
Member: 540344
Sonork: **** u GSMman
Thanks Meter: 110
relax......... hehehehehe
dis assymble the unit! flash it with mother board only!
hehehehehehe demanding?lol!
unlocking seems smothly but after unlock it seems dead?
isnt the user is wrong or not doing the right procedure?
Old 12-22-2009, 02:06   #13 (permalink)
arx
Member: 134843
Sonork: none
Thanks Meter: 81
men, we have the same situation....maybe infinity team may think that it is imposible.....but i am looking forward for them to solve this.....w220 S/W:S2.35B
Old 12-22-2009, 02:08   #14 (permalink)
Member: 76018
Thanks Meter: 59
I flashed hundreds of W220... no Mobile died on Flashing...
Are you even sure you can change Freuqencies on Flashing a different EEProm? In any case it should still boot... try to play with cable... sometimes you have to cut an mm... Phones with T191 have alot of CableProblems... so recheck...
@arx: Infinity can`t help you... if a phone is not responsing (that can`t be on a w220) NO ONE can help you. What should an Update do with the phone if it would be dead...
funny guys... doing b**l**** on phones and asking for Updates... funny...
Old 12-22-2009, 02:15   #15 (permalink)
arx
Member: 134843
Sonork: none
Thanks Meter: 81
download for the full flash file the reflash it.
as the thread starter said, IT WON'T CONNECT ALREADY TO THE SOFTWARE..dami ko na na download na flashfile boss....OUR MAIN PROB NOW IS IT WASN'T ABLE TO CONNECT TO THE SW...IT CAN'T BE REFLASH....NO REACTION AT ALL...
THANKS
client not supported! Activation required! please help me supporters?? chamin SAGEM JTAG UNLOCKER 3 02-16-2010 07:05
BB sat problem whit new box help me support team [SOLVED] mateus.assuncao 3GKey / BB-Box 9 01-05-2010 05:53
exca100 supported if yes pls help me support team wiliam Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 1 12-28-2009 17:02
Help Me Support Team DaWizard Smart-Clip 2 09-29-2009 08:36
6151 dead plz help me dk team ..:::Gsm india:::.. BB5 Box by D.K. 3 01-30-2008 17:06
Page generated in 0.24167 seconds with 10 queries
