04-04-2009, 07:25 | #1 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 599037 Status: Offline Thanks Meter: 103 | w220 fone not authorised then i decided to flash the fone write the new eprom also but still same.... after flash it started to show that the fone hacked... then i wrote the eprom calibration backup made the the software but ne fone hangs on the startup logo... plz share the working flash files+ the working eprom file for this fone.. now the fone says that ' fone not authorised' pzl hlp me.. thanx in advance.. |
04-04-2009, 09:12 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | 1. Please, explain what is the reason to ask "where is supporters" each 20 minutes at Saturday at 6AM ? 2. Did you checked C:\Program Files\InfinityBox\Documentation\Unlock_and_repair ? p.s. Information for all users: many users make answers to only one question from the questions that was asked by supporter. It is really terrible situation for supporters (we can not understand reason of this kind of ignorance) so from today we will close any thread if users did not make an answers to all questions that was asked by supporters. Thank you for your understanding and cooperation ! |
04-04-2009, 12:27 | #4 (permalink) | |
Member: 599037 Status: Offline Thanks Meter: 103 | Quote:
well about that folder i never chked it..coz i never knew that ... now u told me.. thanx for that im chking it and soon vl post the results here.. tahanx | |
04-04-2009, 12:32 | #5 (permalink) |
Member: 599037 Status: Offline Thanks Meter: 103 | fone ok noiw with repair option.. thanx for the directiona nd hlp.. COM48 [Serial2] selected module v1.30 Device: Motorola-W220 "advanced chip detection" active Action: repair Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb software version: 1270-000 software version: SCY-7- Check hardware done Read data ... reading Motorola-W220_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Motorola-W220_eeprom_calibration-1_20090404-170114.6AE.bin Read data done Check data ... Check data done Write ... ......data prepared Ok flash: 89886400010001:89886400000000 Write: eeprom Write done Finished, time used: 22 sec Remove/Install battery now ! |
The Following User Says Thank You to peter002 For This Useful Post: |
04-05-2009, 19:29 | #6 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
Hwk: Not Authorised, Use Update Tool | reignsmart | HWK | 12 | 05-31-2007 15:40 |
Hwk: Not Authorised, Use Update Tool | marisarauso | HWK | 0 | 05-16-2007 11:17 |
Key File not Authorised, pls contact support | Mohtech | Redbox | 7 | 12-18-2006 12:54 |
Hwk: Not Authorised, Use Update Tool | shahzaadbutt | HWK | 8 | 11-16-2006 15:01 |
