12-17-2007, 06:00 | #1 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Wanted VSLIDE VIRGIN MOBILE BY MODELBAS If you have VSLIDE VIRGIN MOBILE BY MODELBAS model on hands and ready for tests, please, contact us privately via PM, ICQ 347191919 or [email protected] Thanks ! |
12-17-2007, 23:03 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: ALGERIA™ Age: 45
Member: 192681 Status: Offline Sonork: 100.106870 Thanks Meter: 5,082 | hello u need a VSLIDE VIRGIN MOBILE BY MODELBAS but i got today VTOUCH VIRGIN MOBILE BY MODELBAS It's similar to him locked to virgin mobile and on 24/48h I get his own cable . some infos is uploaded on ur FTP see u tomorrow on ICQ as always sidali. |
01-11-2008, 23:37 | #4 (permalink) |
Member: 192681 Status: Offline Sonork: 100.106870 Thanks Meter: 5,082 | GET INFINITY BOX AND UNLOCK IT FOR FREE 03 Jan 2008: Modelabs V-Slide Virgin model supported "MModule" v2.03 uploaded in support area: .Modelabs V-Slide Virgin model supported |
07-09-2008, 15:04 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, Please, explain what is the problem exactly so we will be able to understand the problem and tell you what to do. We understand that it's not good, but untill now we have no any special mental skills to read other people's mind remotely so we can not understand the problem without detailed explanation. We are very sorry for this our stupidity ! |
07-09-2008, 17:12 | #8 (permalink) |
Insane Poster Join Date: Apr 2005 Age: 51
Member: 139206 Status: Offline Thanks Meter: 9 | ==== log opened: [09/07/2008 17:57:27] ==== Application: C:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.25 S/N: 0379:010F Wait... Device: Modelabs-V-Slide Virgin Done COM3 selected Device: Modelabs-V-Slide Virgin Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8A01]... CPU: MT6219 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: C:\Program Files\InfinityBox\MModule\eeprom_20080709-180124.B0E.bin flash: 01227E22212200:29EA0000000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... detecting additional parameters... .................................................. .............. error: additional parameters detection failed Special operation Done Write... flash: 01227E22212200:A6BDF700000000 Write: eeprom error: error# 0000AFA4 error: flash write error: 00FF4000:00002000 error: error# 0000AFA4 error: flash write error: 00FF4000:00002000 error: error# 0000AFA4 error: flash write error: 00FF4000:00002000 error: error# 0000AFE4 error: flash write error: 00FF4000:00002000 error: error# 0000AFA4 error: flash write error: 00FF4000:00002000 error: error# 0000AFA4 error: flash write error: 00FF4000:00002000 error: error# 0000AFA4 error: flash write error: 00FF4000:00002000 error: error# 0000AFA4 error: flash write error: 00FF4000:00002000 error: error# 0000AFA4 error: flash write error: 00FF4000:00002000 error: error# 0000AFE4 error: flash write error: 00FF4000:00002000 Write Fail Finished, time used: 146 sec Remove/Install battery now ! |
07-09-2008, 17:14 | #9 (permalink) |
Member: 139206 Status: Offline Thanks Meter: 9 | log opened: [15/06/2008 15:16:25] ==== Application: C:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.23 S/N: 090E:010F Wait... Device: Modelabs-V-Slide Virgin Done COM3 selected Action: read codes unlock method: read codes Model: Modelabs-V-Slide Virgin Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 9600 autodetect error: boot phase#2/1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 6 sec Remove/Install battery now ! COM3 selected Action: read codes unlock method: read codes Model: Modelabs-V-Slide Virgin Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 9600 autodetect error: boot phase#2/1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 5 sec Remove/Install battery now ! |
07-09-2008, 17:22 | #10 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 51
Member: 62419 Status: Offline Thanks Meter: 66 | unlock ok i tested one yesterday with Pinfinder , and all is ok Code: log opened: [07-07-2008 18:05:50] ==== Application: C:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.24 S/N: ****:**** Wait... Device: Modelabs-V-Touch Virgin Done COM3 [VCP1] selected Action: read codes unlock method: read codes Model: Modelabs-V-Touch Virgin Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:44C1:9A8A Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: DS630VG_CC33_V003_HIO_070528 Version: DS630_MP 60 byte(s) read imei: 35576********* connection Ok 208 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: On Corporate lock: Off IMSI lock: Off Auto lock: Off NP of SP: 208-01 SP code: 21907665/12096756 Phone code: 1122 Finished, time used: 12 sec Remove/Install battery now ! COM3 [VCP1] selected Device: Modelabs-V-Touch Virgin Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:44C1:9A8A boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................................................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: C:\Program Files\InfinityBox\MModule\eeprom_20080707-181053.B0E.bin flash: 89881500010001:89881500000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... detecting additional parameters... ...................... flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write: area 0/1 .......................................... additional parameters detected Ok Special operation Done Write... flash: 89881500010001:89881500000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 143 sec Remove/Install battery now ! |
07-09-2008, 17:36 | #11 (permalink) |
Member: 139206 Status: Offline Thanks Meter: 9 | with Pinfinder ???? ................ i'm tested too ==== log opened: [09/07/2008 13:58:11] ==== Application: C:\Program Files\InfinityBox\PinFinder\PinFinder.exe Initializing... software version: 1.11 Smart-Card S/N: Smart-Card firmware version: 010F Initializing PinFinder... Initializing database... base database version: 01 user database version: 01 Initializing cable list... Initializing platforms... Loading configuration... Initialization finished searching adapter at COM3... adapter found, version: 2000 Serial No: done Initializing... done Cable: 1x5 (L5A) Power Off ! software version: 1.11 cable type: 1x5 (L5A) platform: MT6205, MT6217-MT6228, MT6230 searching adapter at COM3... adapter found, version: 2000 pins: 5, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 17 sec Power Off ! Power Off ! software version: 1.11 cable type: 1x5 (L5A) platform: MT6205, MT6217-MT6228, MT6230 searching adapter at COM3... adapter found, version: 2000 pins: 5, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 12 sec Power Off ! |
Lobster Mone100 Locked By Virgin Mobile??? | albarka network | HTC & PDA WM( With Touchscreen) | 16 | 02-16-2010 15:36 |
wanted unlock codes for virgin mobile handsets. | Amol Gawade | Nokia CDMA | 1 | 02-01-2009 14:07 |
Vslide Virgin Mobile By Modelbas | allal123 | Multi-Box | 12 | 07-20-2008 18:45 |
virgin mobile ...type NRJ MOBILE PLAYER | farid29 | Infinity-Box | 1 | 06-23-2008 12:47 |
Vslide Virgin Mobile By Modelbas | allal123 | FuriousGold | 7 | 08-24-2007 12:02 |
