Old 03-20-2009, 00:02   #1 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 730
KF600 Not working with Pana01 v1.64
After flash with correct firmware to unlock with v 1.64 don't work, but with old 1.58 its ok.
Please Infinity Team correct this bug.
With v1.64
COM5 [VCP0] selected
module  v1.64
Device: LG-KF600
Checking data, wait...
Action: unlock
direct unlock
Boot ...
s-gold3: D4
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0000:0000
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
loading data...
error: source buffer too small: 00000000 instead of 000035AE
backup critical area Done
Check memory ...
loading data...
error: operation terminated [00FF]
loading data...
loading data...
loading data...
error: can't read codes
error: not locked or unknown eeprom
Check memory Failed
Finished, time used: 42 sec
Remove/Install battery now !
With v 1.58:
module  v1.58
Device: LG-KF600
Action: unlock
read unlock codes
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0000:0000
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Archivos de programa\InfinityBox\Pana01\LG-KF600_eeprom-static_20090319-185416.B1E.bin
loading data...
data loaded
imei: 01143700425963700
Check memory ...
loading data...
data loaded
code: 91208566
code: 0000000000000000
Finished, time used: 22 sec
Old 03-26-2009, 18:52   #2 (permalink)
dxm
Member: 36443
Can you give me this 1.58 ? Thanks
Old 03-26-2009, 21:19   #3 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
ok thanks for info infinitysupport fixed bug
Old 04-02-2009, 11:09   #4 (permalink)
Member: 96402
Thanks Meter: 4
not yet ...
not fixed the BUG yet .... always the same F**KIN error......
Bird F301 not boot with pana01. Celhack Infinity-Box 0 01-28-2010 15:46
Still on Pana01 V1.64 update mohammed ako Infinity-Box 1 03-22-2009 18:22
8150 not working with latest v1.0.0.2247 snake FuriouS II 2 04-28-2006 12:23
Page generated in 0.14890 seconds with 9 queries
