08-28-2007, 19:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2003 Location: bestncheap Age: 43
Member: 19785 Status: Offline Thanks Meter: 1,242 | what wrong with my china phone 6300?? All Succes Can Not Powered...!! Device: Autodetect Checking data, wait... advanced flash detection active Action: write flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC22E000000000:29EA0000000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb detecting chip #01 in region #00... flash: EC22E000000000:1C043500000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC22E000000000:29EA0000000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb detecting chip #01 in region #00... flash: EC22E000000000:1C043500000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb number of flash chip/regions detected: 02/01 total flash region size: 01000000 detecting eeprom area in 2 chip(s)... flash: EC22E000000000:29EA0000000000 checking area[00000000]: 00000000-007FFFFF... flash: EC22E000000000:1C043500000000 checking area[00800000]: 00000000-007FFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 01 eeprom area detected[00800000]: 00600000-007FFFFF reading [eeprom]... file saved: backup_eeprom_20070829-012843.B0E.bin flash: EC22E000000000:29EA0000000000 Check space Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification detection finished Area: Firmware flash: EC22E000000000:29EA0000000000 Write: Firmware jump to next chip[01] flash: EC22E000000000:1C043500000000 Write: Firmware structure: 2nd [enhanced] (or higher) generation warning: probably identification data damaged, power-on problem possible Probably identification data damaged, device id: 832C9EB1 firmware version: MT26_4LANG_PCB01_GPRS_MT6226_S01.Z6_070403_01_4LAN G.BIN_6D9DD6D2 RPL file must be in folder: C:\Program Files\InfinityBox\ChineseMiracle\ You can create RPL from ASK via client/server right now and press YES. Do you want to write RPL file now ? flash: EC22E000000000:29EA0000000000 flash: EC22E000000000:29EA0000000000 Write: rpl rpl write ok identification detection finished device-id: 832C9EB1 protocol ver: 04 ver. sw1: MT26_4LANG_PCB01_GPRS_MT6226_S01.Z6_070403_01_4LAN G.BIN ver. sw2: Z6.070403.01.4LANG ffs offset/size: 00E00000/00200000 Write Done Finished, time used: 618 sec Remove/Install battery now ! BR BnC |
08-28-2007, 21:25 | #4 (permalink) | |
Member: 19785 Status: Offline Thanks Meter: 1,242 | Quote:
still can not power on... try flashing with other firmware.. same.. ( totaly for 6300 i just get 2kind firmware from support area) only that 2 firmware?> any body can help me to provide other 6300 chinaphone? br bnc | |
08-28-2007, 21:56 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | if you know original phone firmware version (f.e. like MT26_4LANG_PCB01_GPRS_MT6226_S01.Z6_070403_01_4LAN G) you need to use firmware with similar name, not important that phone model name is not the same as your phone name. |
08-29-2007, 07:35 | #6 (permalink) | |
that still s.w problem or h.w problem?? or cause by wrong s.w? br bnc | |
09-12-2007, 22:10 | #9 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | thanks for the info zzz.. i also got the same problem can you upload 6300 backup file here...? thanks i need this too i also got the same problem... mobile working but not display waiting |
plez help 6500s no script,what wrong with my phone? | freedomqn | Infinity-Box | 3 | 10-03-2008 20:03 |
whats wrong with my smartmovie??? | smartzac | Nokia Multimedia | 7 | 04-25-2005 04:46 |
Whats wrong with my x600? Unlocked, not working! | icarus2 | SYSOL Platform | 7 | 10-02-2004 15:22 |
Program which cann tell whats wrong with my phone | ascona202000 | Nokia Multimedia | 7 | 09-27-2003 01:08 |
