Old 11-02-2016, 14:38   #1 (permalink)
Member: 1418143
Thanks Meter: 353
What's wrong with SPD TOOL ? is me or soft issue ?
other Tool ( sorry for that )
Action : Read Info
Boot : SC7731C-EMMC
Tips:
1.Remove Battery, Insert usb cable, Insert battery
2.power off Phone, Remove & Reinsert Battery , insert USB Cable
(In Case Some Phone Required to hold bootkey)
Waiting for Phone Usb....
Phone found : SPRD U2S Diag (COM14)
Connecting...
Bootstrap: SPRD3
Connected done.
sending 1st boot...
waiting for ack...
1st boot done.
Sending 2nd boot...
2nd boot done.
Checking H/W report info...
Read info is done.
Reading Project Property ...
Brand : Infinix
Phone Model : X510
Android Ver : 5.1
CPU/Processor : SP7731C_V1.0.0
SPD Project ver : VERSION_V06_20160516
SW Version : VERSION_V06_20160516
Action completed
Time taken : 00:00:49
Reconnect Battery/USB Cable
Infinity
Card found: S/N : xxxxx , v0134
Chinese Miracle II [SPD module] v 1.22
Operation : Check/Read Info [ v1.22 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 14 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
Boot failed!
Reconnect Power/Cable!
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
Phone found! [ 14 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Sync...
Phone Initial Info :
Platform : MOCORTM_14B_7731C_W16.12.2_Debug
Project : sc7731C_CP0_modem
HWInfo : sc7731C_CP0_modem
Compile : 03-11-2016 21:00:19
Phone Security Info :
IMEI [1] : 359869060275224
IMEI [2] : 359869060275232
BT_ADDR : 000000000000
SelfInfo :
BatVoltage : 3.649 V
Done
Old 11-02-2016, 14:41   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. You have try all boot mode? SC7731C and Alt?
Old 11-02-2016, 14:52   #3 (permalink)
Member: 1418143
Thanks Meter: 353
yeah br , I tried 1 by 1 , with and without ALT .
Old 11-02-2016, 15:01   #4 (permalink)
Member: 599037
Thanks Meter: 103
same problem with me, spd tools doesnt work at all, all boot methods failed
The Following User Says Thank You to peter002 For This Useful Post:
Old 11-02-2016, 15:50   #5 (permalink)
JayDi's Avatar
Member: 462970
Then it mean that HW (EMMC/DRAM pair) not supported yet.
Remove it and not use. Be happy.
Old 11-02-2016, 16:23   #6 (permalink)
Member: 1418143
Thanks Meter: 353
the issue isn't this phone only , I faced same things with lot of SPD !!!
Old 11-02-2016, 17:20   #7 (permalink)
JayDi's Avatar
Member: 462970
In fact that can't help me in any case.
Loaders package updated in every version according phones, which have chance to get and verify.
Old 11-02-2016, 17:28   #8 (permalink)
Member: 1418143
Thanks Meter: 353
so what can I do to help u ? I have phone right now
Old 11-02-2016, 17:36   #9 (permalink)
Member: 2203712
Sonork: 100.1667064
Thanks Meter: 82
Start at : [10/7/2016 / 9:36:54 AM]
3. Insert cable
Phone found! [ 20 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : X510
Model Brand : Infinix
Model Device: X510
AndrVersion : 5.1
BaseBand CPU: SP7731CEB
CompileDate : 4/26/2016 1:23:35 AM
Project Ver : VERSION_V05_20160425
Model Ext : X510
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:26
Finish at : [10/7/2016 / 9:37:22 AM]
Start at : [10/7/2016 / 9:54:22 AM]
Operation : Read FullFlash [ v1.22 ]
3. Insert cable
Phone found! [ 20 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Detected eMMC Flash , Structure detect Ok!
[FW_READER] : Prepare Ok!
- > Wait phone connected ...
Phone found! [ 20 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Phone found! [ 20 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name : X510
Model Device: X510
AndrVersion : 5.1
Model Ext : X510
[Read Mode] : HSUSB : 0x3000
[FW_READER] : Reading Firmware Now ...
[Read Ok] : u-boot-spl-16k.bin
[Read Ok] : u-boot.bin
[Read Ok] : prodnv.img
[Read Ok] : sc7731C_CP0_modem.bin
[Read Ok] : DSP_DM_Gx.bin
[Read Ok] : nvitem_w.bin
[Read Ok] : sc8830g_modem_CP2_Trunk_W15.49.3_Release.bin
[Read Ok] : nvitem_wcn.bin
[Read Ok] : logo_480x854.bin
[Read Ok] : fblogo_480x854.bin
[Read Ok] : boot.img
[Read Ok] : system.img
[Read Ok] : oem.bin
[Read Ok] : sysinfo.bin
[Build Ok] : cache.img
[Read Ok] : recovery.img
[Build Ok] : userdata.img
AndroidInfo created
Firmware Size : 1942 MiB
Saved to : C:\InfinityBox\CM2SPD\Flash\SP7731CEB_X510_5.1_VER SION_V05_20160425_X510\
Done!
Elapsed: 00:16:01
Finish at : [10/7/2016 / 10:10:25 AM]
The Following 3 Users Say Thank You to papinto For This Useful Post:
Old 11-02-2016, 17:42   #10 (permalink)
Member: 2203712
Sonork: 100.1667064
Thanks Meter: 82
so what can i do to help u ? I have phone right now
have a look brother......the power of cm2 at permalink (9)
Old 11-02-2016, 17:47   #11 (permalink)
Member: 1418143
Thanks Meter: 353
which version of windows use You ?
Old 11-02-2016, 17:49   #12 (permalink)
JayDi's Avatar
Member: 462970
Seems as you need select SC7731 with AltLDr ( A6/CRev )
According previous report log.
Old 11-02-2016, 17:51   #13 (permalink)
Member: 2203712
Sonork: 100.1667064
Thanks Meter: 82
I HAD BOOT FAILED IN WINDOWS 7 SO I TRIED IT ON WINDOWS XP SP3 AND IT WORKED...NOTHING ELSE
I USED SC7731 Android 6 / CRev AS MY BOOT (WITHOUT ALTLDR)
TRY IT AND REPORT RESULT HERE
BEST OF LUCK
Old 11-02-2016, 17:54   #14 (permalink)
Member: 1418143
Thanks Meter: 353
I think it's Windows issue !!
Old 11-02-2016, 19:16   #15 (permalink)
Member: 1745682
Thanks Meter: 49
This is windows issue I faced the same problem. Pls fixed it for windows 7
The Following User Says Thank You to mrnice2 For This Useful Post:
Page generated in 0.26711 seconds with 8 queries
