03-06-2010, 16:32 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Gsmhosting Age: 47
Member: 142191 Status: Offline Sonork: 100.1589775 Thanks Meter: 297 | why vodafone 125 sets are going dead with pana01 recently i flashed vodafone 125 which was in hanging problem...flashed success..but set gone dead after flashing...faced same problem in another set...tried different flash files still set is dead...need help from infinity team...also tried format ffs too..here are logs... COM3 [VCP0] selected module v1.76 Device: ZTE-125 Checking data, wait... Action: write flash Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: -DE-P108A1V1.0.0B02 VDF-P108A1B07-De-DE03 g3dBV2.0 16 59 13 04.1 Check parameters Done backup critical area ... backup critical area Done Check memory ... unlocking... lock found lock type #1 found operation done Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Write Done Finished, time used: 3 min 59 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [3/6/2010 9:00:11 PM] ==== COM3 [VCP0] selected module v1.76 Device: ZTE-125 Checking data, wait... Action: reset settings ("format ffs") Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: -DE-P108A1V1.0.0B02 VDF-P108A1B07-De-DE03 g3dBV2.0 16 59 13 04.1 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20100306-210037.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20100306-210038.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20100306-210045.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 32 sec Remove/Install battery now ! |
03-06-2010, 16:40 | #2 (permalink) |
Member: 142191 Status: Offline Sonork: 100.1589775 Thanks Meter: 297 | here are other examples... here are other examples http://forum.gsmhosting.com/vbb/show...hlight=zte+125 http://forum.gsmhosting.com/vbb/show...hlight=zte+125 http://forum.gsmhosting.com/vbb/show...hlight=zte+125 http://forum.gsmhosting.com/vbb/show...hlight=zte+125 |
The Following User Says Thank You to rk_grover77 For This Useful Post: |
03-06-2010, 17:24 | #3 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | Quote:
03-06-2010, 17:53 | #4 (permalink) |
Member: 142191 Status: Offline Sonork: 100.1589775 Thanks Meter: 297 | sucessfully solved my problem in both sets with old version of pana01 1.65...both phones are working ok now..i think there is bugs in latest version of pana01...reported to infinity team.. |
06-17-2010, 14:24 | #9 (permalink) | |
No Life Poster Join Date: May 2008 Location: india / Tamil nadu
Member: 773423 Status: Offline Thanks Meter: 82 | Quote:
The Following User Says Thank You to gsm_jeevan For This Useful Post: |
Vodafone 125 can't unlock? Why. | dawah telecom | FuriousGold | 3 | 01-22-2009 16:52 |
vodafon 125 after flash for unlock with P108a1b07-de | buqki | FuriousGold | 2 | 04-05-2008 18:16 |
why new ver 50 is going dead???? | petermov | S-Gold Based Phones | 0 | 07-06-2005 10:13 |
