10-31-2016, 20:20 | #1 (permalink) |
Major Poster Join Date: Jul 2013 Location: 127.0.0.1
Member: 1970941 Status: Offline Thanks Meter: 4 | WIKO RAINBOW LITE_4G Read Firmware error Code: Operation : Identify [ v1.00 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require make TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.00 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require make TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 0149F830 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : WIKO ProdName : L5221 ProdModel : RAINBOW LITE 4G Device : L5221 AndroidVer: 5.1.1 Manufact. : WIKO QLMxCPU : MSM8909 Done! Elapsed: 00:00:22 Reconnect Power/Cable! Operation : Read Flash [ v1.00 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require make TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 0149F830 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : WIKO ProdName : L5221 ProdModel : RAINBOW LITE 4G Device : L5221 AndroidVer: 5.1.1 Manufact. : WIKO QLMxCPU : MSM8909 DevInfo : MSM8909__WIKO__WIKO__ANDR_v5.1.1__RAINBOW_LITE_4G__L5221__L5221 Info : Device is not supported yet! Send log and report to support! Include device info also! Reconnect Power/Cable! |
09-18-2017, 16:10 | #2 (permalink) |
Freak Poster Join Date: Nov 2016 Location: Everywhere
Member: 2647496 Status: Offline Thanks Meter: 40 | WIKO RAINBOW LITE_4G Firmware Read Done! Code: Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 0440ADDF ID_BLOCK_I : 009600E1 ID_BLOCK_L : E41C76802FBBA0A39CF1030CCB961E2E ID_BLOCK_L : 1B6AD47778EB53D0F5C0954240AFB982 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000000E9000000 [ eMMC 4 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : WIKO ProdName : L5221 ProdModel : RAINBOW LITE 4G Device : wiko AndroidVer: 5.1.1 Manufact. : WIKO QLMxCPU : MSM8909 DevInfo : MSM8909__WIKO__WIKO__ANDR_v5.1.1__RAINBOW_LITE_4G__wiko__L5221 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : misc.img [Read Ok] : splash.img [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8909 / eMMC Firmware Size : 1168 MiB Done! Elapsed: 00:02:37 |
09-19-2017, 22:50 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | ... just a small hint : After you download OFFICAL UPDATER , after starting it, it will unpack ROM (together with loader) in same folder where exe file started. You can use that file for flashing via CM2 later. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
10-10-2017, 22:00 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | All factory files are supposed to work. I used this updater, and can confirm it's working. Also, unpacked files from ROM folder works for box flashing, too. b.r. Alex
