07-05-2018, 19:26 | #3 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: FMI OF Age: 52
Member: 866455 Status: Offline Sonork: SAMSUNG CPID ONLINE Thanks Meter: 579 | nead to repair network Quote:
1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A01906532474120210705CD38E240 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A48414732650507212040E273CD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xC8E948C28E90C0A075A1837DE553DF9A INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Set IMEI [00] : 352641200xxxxx Set IMEI [01] : 35164xxxxxx Prepare finished. Security check required! Wait for phone... Phone found! [ 6 ] Sync... Repair done! Done! Elapsed: 00:00:49 Reconnect Power/Cable! | |
07-12-2018, 11:57 | #5 (permalink) | ||
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | Quote:
https://mega.nz/#!qkYRSIQb!R7Z-GGhDf...2_rVauNJiQQpqY The exact factory info of the Phone in hand Quote:
The Following User Says Thank You to lyes_albert For This Useful Post: |
07-12-2018, 12:08 | #7 (permalink) | |
Member: 866455 Status: Offline Sonork: SAMSUNG CPID ONLINE Thanks Meter: 579 | Quote:
The Following User Says Thank You to AgicAga For This Useful Post: |
07-12-2018, 12:43 | #10 (permalink) | |
07-12-2018, 12:51 | #11 (permalink) |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | Yo,this is a full security back up, Nvdata and Nvram and Sec files are included, you find a scatter file, which you can pass into the phone via Spflashtool. Good luck https://mega.nz/#F!2kRDwQpT!yNM0NtTTKLpfakaiB3IK_w |
12-19-2022, 14:17 | #12 (permalink) | |
Insane Poster Join Date: Dec 2010 Location: Venezuela
Member: 1473248 Status: Offline Sonork: Tecnico Thanks Meter: 7 | Quote:
Could you please correct the link? I have the same one with blank imei, damaged nvram. Thanks mate Por favor podrias corregir el link? Tengo uno igual con imei en blanco, nvram daņado. Gracias compaņero | |
12-19-2022, 19:39 | #13 (permalink) |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | The file is almost 5 years old I dont still have it, the post goes back to 2018 Unfortunately the link has expired.... |
12-20-2022, 20:30 | #14 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
12-21-2022, 00:52 | #15 (permalink) |
Member: 1473248 Status: Offline Sonork: Tecnico Thanks Meter: 7 | Thanks for the file bro. Even without being able to correct its original imei. Damaged baseband, blank imei. I used Nck and Miracle, but nothing Error, nvram posible damaged. Write good nvram and try again. Wait untill phone will start charging. All done. |
