10-21-2016, 14:03 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | World's 1st Cm2-Lyf Wind-6 Read Pattern Lock With Out Root/Adb Lyf Wind-6 Read Pattern Lock WiTh Out Adb/Root Device Just Simple And Easy Step Read Info Log Code: Operation : Identify [ v1.00 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require make TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 046AB1E4 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : LYF ProdName : LS-5009 ProdModel : LS-5009 Device : LS-5009 AndroidVer: 5.1.1 Manufact. : unknown QLMxCPU : MSM8909 QLMxPRJ : LYF_LS-5009_00_222_160715 Done! Elapsed: 00:00:06 Read Pattern Lock Log Code: Operation : Read PatternLock [ v1.00 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require make TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 046AB1E4 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 4253689 Done! Elapsed: 00:00:45 Reconnect Power/Cable! Last edited by Deepesh Sharma; 10-21-2016 at 14:08. Reason: Add Image |
The Following User Says Thank You to Deepesh Sharma For This Useful Post: |
