09-12-2019, 10:54 | #1 (permalink) | |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | Write Backup MT6580 (PACK FW) - Stuck on FASTBOOT. Quote:
09-13-2019, 19:10 | #2 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 439 | Please INFINITY replied back... The phone was working perfectly. I needed to root the phone so that i can put GAPPS. but was freeze on logo after install !! BUT after trying BACKUP FLASH file now phone stuck on FASTBOOT mode.. What is the problem? |
09-14-2019, 08:47 | #4 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 439 | The phone was working Properly. ONly no GOOGLE apps. SO i make a backup just to be on that SAFE side... NOW after messing up.. i use the backup.. But block on FAST BOOT mode. SO WHAT IS THE USE TO MAKE A FIRMWARE BACKUP???? |
09-14-2019, 11:49 | #5 (permalink) | |
Freak Poster Join Date: Nov 2017 Location: In Your Mind
Member: 2778467 Status: Offline Sonork: only Telegram Thanks Meter: 265 | Quote:
backup rom and flash another same device work only old mtk devices in this era every device need factory signed firmware | |
09-14-2019, 14:18 | #6 (permalink) | |
Member: 64823 Status: Offline Thanks Meter: 439 | Quote:
What is the BACKUP/ READ FW button use for then? Why there is the OPTION there? We are in the NEW ERA... 2019.. Soon 2020 !! | |
09-14-2019, 14:36 | #7 (permalink) | |
09-14-2019, 23:28 | #8 (permalink) | |
Insane Poster Join Date: Aug 2018
Member: 2855925 Status: Offline Thanks Meter: 62 | Quote:
Read firmware is for mostly old Android versions, MANY NEW ANDROID VERSIONS HAVE SECURE BOOT, so if you try to write back readed firmware phone will result in brick/semi dead or stuck on logo/fastboot From your situation your phone is detecting that your system is modified so it kicks/boots to bootloader mode aka fastboot.. ONLY SOLUTION IS SIGNED FACTORY FIRMWARE please for try to attach read firmware logs maybe i can help | |
09-15-2019, 10:20 | #9 (permalink) |
No Life Poster Join Date: Dec 2015 Location: Somewhere on the Internet
Member: 2500215 Status: Offline Thanks Meter: 417 | This might not be secured boot.. The truth is that many backup done by CM2MT2 doesn't work well for nonsecured boot.. I have tried itel P32, itel A32F and other older models.. They don't boot after flash but when I do read back with other tool or older CM2MTK 1.58. The phone works.. |
09-15-2019, 10:20 | #10 (permalink) |
09-15-2019, 10:20 | #11 (permalink) |
09-15-2019, 18:20 | #12 (permalink) | |
09-15-2019, 18:21 | #13 (permalink) | |
