Old 11-10-2007, 14:26   #1 (permalink)
ikkks's Avatar
Member: 621455
Sonork: key4unlock
Thanks Meter: 118
ztc A898 i need pin out n flash file
hiiii
i need pin outs n flash file for ztc a898
Old 11-10-2007, 19:00   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Due to a lot of different models with the same name but absolutely different hardware,
bottom connectors and different pinouts we recommend you to include the next info:
1. detailed description of model
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, check the next detailed description how to get pinout for your model:
use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
Old 11-19-2007, 14:10   #3 (permalink)
Member: 50772
Sonork: 100.1590990
Thanks Meter: 318
http://forum.gsmhosting.com/vbb/show...&postcount=262
Old 12-08-2007, 08:49   #4 (permalink)
ikkks's Avatar
Member: 621455
Sonork: key4unlock
Thanks Meter: 118
thnx 2 aashir n infinity team
hiiiiiii
thnx dear aashir dat pin outs r working thnx ones again dear
keep it up .....................
Old 12-11-2007, 07:51   #5 (permalink)
tarunvishal's Avatar
Member: 308296
Thanks Meter: 152
i have same set problem is set dead when i m attach with infinity softwaare says new finware detected send to the support but i m need new flash fuile for live this set again
backup_flash[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08_26B_HL_L5 SM_204_070918_LD-TR0_OV0_SS
Old 12-11-2007, 13:15   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello tarunvishal!
first send you flash backup to us.
we will check it. also: did you try to make complete format?
Old 12-14-2007, 13:06   #7 (permalink)
Member: 652693
Hi ,
I got new Ztc A898 mobile . There option of mobile view is not working.
Also i couldnt connect to GPRS even through service operator sent the details .
Old 12-14-2007, 13:57   #8 (permalink)
Member: 148515
hello!
you can try safe backup- maybe it will help you.
all other operation only after you make full backup
need pin out for ztc e99 urgent manish665 Chinese Cocktail 1 04-10-2008 08:41
need pin out for ztc e99 urgent manish665 Infinity-Box 1 04-08-2008 19:40
need pin out for ztc e99 urgent? manish665 SpiderMan 0 04-08-2008 19:20
need pin out to ztc t/600 n-box SpiderMan 3 03-16-2008 00:30
ztc988 need pin outs n flash file ikkks Infinity-Box 3 12-10-2007 17:42
Page generated in 0.19868 seconds with 9 queries
