01-27-2021, 15:34 | #1 (permalink) |
Product Supporter Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Xiaomi Mi Play (Lotus) Successfully Flashed by CM2 Code: Operation : HW Report [ v2.18 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM24) MODE : BOOTROM PORT : 24 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 195ED31C7D59B1C9FDEC70F5013D02BF BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : A8FF7441CC4430200F1FF8FC5FAC5392C3AC44A0C593F721E496D00D390F97DB BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0004 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 90014A68433861503E03607A1C36DF EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hC8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 4DB307F3D1BFEA049EF8AADD1F544D2 DA : USB : HIGH-SPEED Boot done! Memory Info : CID : 90014A68433861503E03607A001C36DF MEM : VEN : HYNIX | OEM : 4A01 | DEV : hC8aP> DAT : Size: 59640 MB, Max.Speed: 52000 kHz, blklen(512), nblks(122142720), ro(0) EXT_CSD Info : EXT_CSD rev. : v1.8 ( MMC v5.1 ) CSD struct rev. : v1.2 Supported command sets : 1h HPI features : 1h BG operations support : 1h BG operations status : 0h Correct prg. sectors : 0h 1st init time after part. : 1000 ms Min. write perf.(DDR,52MH,8b): 0h Min. read perf. (DDR,52MH,8b): 0h TRIM timeout: 0 ms Secure feature support: 55h Secure erase timeout : 150000 ms Secure trim timeout : 150000 ms Access size : 3584 bytes HC erase unit size : 512 kbytes HC erase timeout : 600 ms HC write prot grp size: 8192 kbytes HC erase grp def. : 0h Reliable write sect count: 1h Sleep current (VCC) : 8h Sleep current (VCCQ): 9h Sleep/awake timeout : 419430400 ns Sector count : 747c000h Min. WR Perf. (52MH,8b): 8ch Min. Read Perf.(52MH,8b): 8ch Min. WR Perf. (26MH,8b,52MH,4b): 46h Min. Read Perf.(26MH,8b,52MH,4b): 46h Min. WR Perf. (26MH,4b): 1eh Min. Read Perf.(26MH,4b): 1eh Power class: 0 Power class(DDR,52MH,3.6V): 0h Power class(DDR,52MH,1.9V): 0h Power class(26MH,3.6V) : 0h Power class(52MH,3.6V) : 0h Power class(26MH,1.9V) : 0h Power class(52MH,1.9V) : 0h Part. switch timing : 1h Out-of-INTR busy timing: ah Card type : 57h Command set : 0h Command set rev.: 0h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 2h Boot area write prot : 0h User area write prot : 0h FW configuration : 0h RPMB size : 16384 kbytes Write rel. setting : 1fh Write rel. parameter: 15h Start background ops : 0h Enable background ops: 2h H/W reset function : 1h HPI management : 0h Max. enhanced area size : e8fh (30531584 kbytes) Part. support : 7h Part. attribute: 0h Part. setting : 0h General purpose 1 size : 0h (0 kbytes) General purpose 2 size : 0h (0 kbytes) General purpose 3 size : 0h (0 kbytes) General purpose 4 size : 0h (0 kbytes) Enh. user area size : 0h (0 kbytes) Enh. user area start: 0h Bad block mgmt mode: 0h Overall status : MLC status : 0% - 10% used SLC status : Not defined EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY EXISTS! [State : NOT CLEAN : UNUSABLE] Done! Code: Operation : Write Flash [ v2.18 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :22 [FL] : Set : preloader_lotus.bin [FL] : Set : recovery.img [FL] : Set : efuse.img [FL] : Set : md1img.img [FL] : Set : spmfw.img [FL] : Set : scp.img [FL] : Set : scp.img [FL] : Set : sspm.img [FL] : Set : sspm.img [FL] : Set : lk.img [FL] : Set : lk.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : odmdtbo.img [FL] : Set : tee.img [FL] : Set : tee.img [FL] : Set : vendor.img [FL] : Set : cust.img [FL] : Set : system.img [FL] : Set : vbmeta.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xE7A0BB00 [ 3.62 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM24) MODE : BOOTROM PORT : 24 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 195ED31C7D59B1C9FDEC70F5013D02BF BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : A8FF7441CC4430200F1FF8FC5FAC5392C3AC44A0C593F721E496D00D390F97DB BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6765 EMI : SRC : preloader_lotus.bin EMI : CNT : 000A EMI : [00] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 150100334836434142 : VEN : SAMSUNG | DEV : 3H6CAB : RAM : [ 6.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 6.00 GB ] EMI : [09] : eMMC : LP_DDR4X : ID : 450100444134303634 : VEN : SANDISK | DEV : DA4064 : RAM : [ 4.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 90014A68433861503E03607A1C36DF EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hC8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 4DB307F3D1BFEA049EF8AADD1F544D2 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000003688000 Erase : 0x0000000005688000 : 0x0000000006000000 Erase : 0x000000000C800000 : 0x0000000000800000 Erase : 0x0000000010000000 : 0x0000000000200000 Erase : 0x0000000010500000 : 0x0000000008980000 Erase : 0x000000001CE80000 : 0x0000000204980000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : EFUSE Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : ODMDTBO Write : TEE1 Write : TEE2 Write : VENDOR Write : CUST FAIL : SEC : IMG TOO LARGE Write : SYSTEM Write : VBMETA Write : CACHE Write : USERDATA Ultra : Ok! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! |
The Following 8 Users Say Thank You to dr_moosavi For This Useful Post: |
01-27-2021, 19:30 | #2 (permalink) |
No Life Poster Join Date: Apr 2008 Location: In My ThinkPad
Member: 756569 Status: Offline Thanks Meter: 185 | I have same device with MI account Lock. Can you please show me how to Rewrite or Format "presist". Please upload video gide if possible. Best regard |
02-06-2021, 11:17 | #3 (permalink) |
Registered User Join Date: Sep 2012 Location: Rawalpindi, Pakistan
Member: 1809208 Status: Offline Thanks Meter: 28 | Code: Card found : 3EA4381E , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v21168 Ok! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 7BF2326B78456E193524BB46BC9A9AF3 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 62463A53389E06633DDD493267C19735DD0A8218660F11E678575DA4C4D92261 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 7BF2326B78456E193524BB46BC9A9AF3 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : 6A_MIPlay | Manual : Disabled BROM : SOCID : 62463A53389E06633DDD493267C19735DD0A8218660F11E678575DA4C4D92261 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 7BF2326B78456E193524BB46BC9A9AF3 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : 6A | Manual : Disabled BROM : SOCID : 62463A53389E06633DDD493267C19735DD0A8218660F11E678575DA4C4D92261 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT0000 , SBID : 0x0000 , HWVR : 0x0000 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x00|0xFF BROM : BOOTROM MODE : Xiaomi : 6A_MIPlay | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 7BF2326B78456E193524BB46BC9A9AF3 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 62463A53389E06633DDD493267C19735DD0A8218660F11E678575DA4C4D92261 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 7BF2326B78456E193524BB46BC9A9AF3 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 62463A53389E06633DDD493267C19735DD0A8218660F11E678575DA4C4D92261 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 7BF2326B78456E193524BB46BC9A9AF3 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 62463A53389E06633DDD493267C19735DD0A8218660F11E678575DA4C4D92261 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 7BF2326B78456E193524BB46BC9A9AF3 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 62463A53389E06633DDD493267C19735DD0A8218660F11E678575DA4C4D92261 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 7BF2326B78456E193524BB46BC9A9AF3 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 62463A53389E06633DDD493267C19735DD0A8218660F11E678575DA4C4D92261 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 7BF2326B78456E193524BB46BC9A9AF3 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 62463A53389E06633DDD493267C19735DD0A8218660F11E678575DA4C4D92261 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Memory Tool Init [ v2.21 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 7BF2326B78456E193524BB46BC9A9AF3 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 62463A53389E06633DDD493267C19735DD0A8218660F11E678575DA4C4D92261 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
02-10-2021, 23:56 | #4 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
02-18-2021, 16:37 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | |
03-29-2021, 01:33 | #7 (permalink) |
Freak Poster Join Date: Jun 2005 Location: kl Age: 40
Member: 151678 Status: Offline Thanks Meter: 22 | xiaomi mi play, i cannot flash or identify phone, whats wrong Operation : Identify [ v2.20 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM15) MODE : BOOTROM PORT : 15 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.20 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM15) MODE : BOOTROM PORT : 15 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : FEC385D54E0837E879C8F59DBDFDC92F BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : 6A_MIPlay | Manual : Disabled BROM : SOCID : 77383E7EAAA7DBB8012C50C750900D8C9AE4F204F63ED2C36B 01325F5879BA94 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SETUP HW PARAMS FAILED! PROTO_VER is OLD? Error : Fail to init protocol! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! |
