09-13-2017, 19:24 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Bulgaria
Member: 877235 Status: Offline Sonork: vasilbojilov Thanks Meter: 199 | Xiaomi redmi note 4 dead make read back via CM2MTK: 1 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Xiaomi Device Model : nikel Device CPU : MT6797 Device IntName : nikel Device Version : 6.0 Device Compile : 18.10.2016 �. 08:45:14 Device Project : alps-mp-m0.mp9-V1.64_lcsh6797.6c.lw.m_P101 Device ExtInfo : Redmi Note 4 2 after flash via latest Global ver. with SPFLASHTOOL get error ,, CUST_FILE IS TOO LARGE 3 replace cust file with same small .cust file(modified) get error sec_file_type_mismatch 4 When try reflash via already created infinity readback firmware and get that: Card found : S/N : CD6xxx , v0136 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6797 , Project : lcsh6797_6c_lw_m , Storage : EMMC Files found : 18 , Set to Flash : 17 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Xiaomi Device Model : nikel Device CPU : MT6797 Device IntName : nikel Device Version : 6.0 Device Compile : 18.10.2016 ã. 08:45:14 Device Project : alps-mp-m0.mp9-V1.64_lcsh6797.6c.lw.m_P101 Device ExtInfo : Redmi Note 4 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6797 BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from ScatFW! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R4BNJ [eMMC] : FLASH_CID : 150100424A4E42345207633E4A128309 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xB53C8A2EAD2D40334DE61348475B3821 INT RAM : 0x00000000 EXT RAM : 0xC0000000 [3 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! ScatCFG : BaseBand : MT6797 , Project : lcsh6797_6c_lw_m , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled M67BL : Check eMMC compatibility BL : Undefined structure, determined as forced M67BL : eMMC supported by BootLoader! Selected forced PMT update Build new PMT ... Update Primary ... Update Mirror ... PMT update Ok! M67BL : Flash Erase Total blocks to Erase : 5 Erase : 0x0000000000008000-0x0000000001A80000 Erase : 0x0000000002288000-0x0000000004000000 Erase : 0x0000000007800000-0x0000000000A00000 Erase : 0x0000000008500000-0x0000000002600000 Erase : 0x000000000B000000-0x00000007390FBE00 Flash Erase Done, time used : 00:00:03 Processing : Writing all Flash Files Flash Partition : PRELOADER Flash PLC Image Flash Ok Flash Partition : RECOVERY Image Flash Failed! Something wrong with files or connection! Operation Failed Elapsed: 00:00:31 Reconnect Power/Cable! now stuck on MI LOGO any suggestions? |
09-13-2017, 21:33 | #3 (permalink) |
Member: 877235 Status: Offline Sonork: vasilbojilov Thanks Meter: 199 | Brother, WHAT you mean FACTORY firmware????? I think that source is ,,FACTORY,, Xiaomi MIUI Official Forum Please, i need meaningful suggestions !!! |
09-14-2017, 05:22 | #5 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2583580 Status: Offline Thanks Meter: 4 | Xiaomi phons comes with signed firmwares. U cannot always flash readback firmware to these phones Find stock firmware from somewhere and flash with official flash tool. Mi oppo vivo. And other secured bootloader phones. If uneed any help with mi not 4 Wtsp me 0097556188440 Sent from my SM-N920C using Tapatalk |
