03-19-2022, 16:21 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Y21 2021 V2111 New Security Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM13) MODE : PRELOADER PORT PORT : 13 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM13) MODE : PRELOADER PORT PORT : 13 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Last edited by .::MASTER ALONE::.; 03-19-2022 at 16:26. Reason: Attachment Issue |
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post: |
03-19-2022, 16:41 | #3 (permalink) | |
Banned Join Date: Oct 2016 Location: In Your Heart
Member: 2636401 Status: Offline Thanks Meter: 2,332 | Hello Bro See Attentively In My Case Removed FRP Successfully Without Any Error Quote:
See Logs Attentively KING INFINITY CM2 DONE Without Any Error Smoothly Like A Charm Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : C8ED3599E765F97A6A2AA6560837EA90 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 54C41906E127260E7EF5C27E73DF69BF158D2267768B2383E0 F47D3904575720 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v05.05.05 on MT6765 FireFly : eMMC init passed! EMMC: CSD : D02701320F5903FFF6DBFFEF8E40400D EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 15010044503644414202209568F048E3 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444142 : PRV : 0x02 EMMC: VEN : SAMSUNG : DP6DAB EMMC: SNN : 546662640 ( 0x209568F0 ) , MF : 4/2021 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [CONFIG] : 0x48, 0x02, 0x01 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [RST_N_FUNCTION] : 0x01 EMMC: EXTCSD [PART_S_COMPLETED] : False EMMC: EXTCSD [SIZE] : Market : 64 GB EMMC: EXTCSD [SIZE] : Actual : 0xE8F800000 [ 58.24 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:40 Reconnect Power/Cable! | |
03-19-2022, 17:31 | #4 (permalink) |
Registered User Join Date: Aug 2016 Location: Multan Pakistan
Member: 2608490 Status: Offline Thanks Meter: 921 | @kk3 Bacause In your case phone have brom port which simply can be activate by pressing vol keys. In New Security Brom closed by Vivo Only preloder port work. So no magic in you. Please do not Confuse other users. For now me also have got 2,3 vivo phone brom closed which cannot boot in preloader port with cm2. |
The Following 4 Users Say Thank You to GSM AR For This Useful Post: |
03-19-2022, 17:44 | #5 (permalink) | |
Member: 2636401 Status: Offline Thanks Meter: 2,332 | Hello Sir Quote:
03-19-2022, 20:13 | #6 (permalink) | |
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
2022-02-1 New Security All Mtk Brand Not Boot BROM Mode Dear. | |
03-20-2022, 03:21 | #7 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Select vivo sec_6765 do service in preloader mode All vivo model with 6765 can do by this |
The Following 3 Users Say Thank You to kamal_singla For This Useful Post: |
03-20-2022, 03:21 | #8 (permalink) |
03-20-2022, 05:36 | #9 (permalink) |
Member: 2608490 Status: Offline Thanks Meter: 921 | Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : Vivo : Y15-Y30 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : Vivo : Y15-Y30 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Cannot boot with Brand / Model wise. Here is Phone info Code: Reading Partition Table... Storage : eMMC Reading Information... Build Date : Thu Feb 10 23:36:17 CST 2022 Build Flavor : full_k65v1_64_bsp-user Build Desc. : full_k65v1_64_bsp-user 11 RP1A.200720.012 eng.compil.20220210.233920 release-keys Android Ver. : 11 Display ID : RP1A.200720.012 release-keys Patch Level : 2022-02-01 Platform : MT6765 Board : k65v1_64_bsp Platform : mt6765 |
03-20-2022, 12:00 | #10 (permalink) | |
Member: 2608490 Status: Offline Thanks Meter: 921 | Quote:
Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : Vivo : SEC_MT6765 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] EMMC: CID : 150100525036344D4201FCAED01E7655 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 525036344D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : RP64MB EMMC: SNN : 4239314974 ( 0xFCAED01E ) , MF : 7/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 10936BE5176BB926F4FE522B9513E44B DA : USB : HIGH-SPEED Boot done! Product Brand : vivo Product Device : 1901 Product Model : vivo 1901 Product Name : 1901 Patch Level : RP1A.200720.012 Display ID : RP1A.200720.012 release-keys Product Info : k62v1_64_bsp Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2022-02-01 Build Time : 18.02.2022 Product Board : k62v1_64_bsp Board Platform : mt6765 Product Manfct : vivo USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption **) NVRAM : BBK_R0MP1_K62V1_64_BSP_MDBIN_PCB01_MT6765_S00.MOLY _LR12A_R3_MP_V136_6_P74 NVRAM : 0xB50AF66F NVRAM : State : Ok! INFO : WiFi MAC : AA0036004400 INFO : BlTh MAC : 08B3AFD1F27E INFO : IMEI[1] : 8625xxxxxxxxxxxx INFO : IMEI[2] : 8625xxxxxxxxxxxx Backup sensetive data [ 18 ] Backup path : Backup\MT6765__10936BE5176BB926F4FE522B9513E44B\ [29] Read : NVRAM [8] Read : NVDATA [19] Read : PROINFO [30] Read : LK [7] Read : NVCFG [14] Read : PROTECT1 [1] Read : PGPT [17] Read : PERSIST [0] Read : PRELOADER Backup done! STORAGE : Life Status : eMMC : NOT implemented in selected DA! STORAGE : OTP Status : NOT Enabled! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Done! Elapsed: 00:00:26 | |
07-30-2022, 07:21 | #12 (permalink) | |
No Life Poster Join Date: Apr 2013 Location: Uzbekistan / Bukhara
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 622 | Quote:
The Following User Says Thank You to UzUnlocker For This Useful Post: |
