Old 03-28-2009, 16:01   #1 (permalink)
Member: 243158
Thanks Meter: 25
yingtai tv8000 not power on
plz help me .after ( format ffs: complete mode ) phone not power on
Old 03-28-2009, 21:27   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please post full format LOG. there is alot of usefull information
I hope you tried to keep power button pressed around 30seconds, and battery is full charged?
i am asking, becuase this is most common mistakes
Old 03-30-2009, 16:27   #3 (permalink)
Member: 243158
Thanks Meter: 25
COM5 [VCP0] selected
module v2.79
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:4803:000A
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B18E7E32.[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN_0 9B2A37C].rpl
identification#1 detection finished
device-id: B18E7E32
identification#1 protocol ver: 04
ver. sw 1: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN
ver. sw 2: UPU25U26V03B09, 835C4DF6
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN]_20090330-152506.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_B18E7E32_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V03B09.BIN_09B2A37C_20090330-152526.B0X.bin
Finished, time used: 142 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Thanks in advance.
Old 03-30-2009, 20:41   #4 (permalink)
Member: 148515
hello!
flash phone with firmware available on support area:
[bin] flashfiles/ChineseMiracle/_MT6226/U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09_16m_E n_Fr_Ar.B0M.bin
Old 03-31-2009, 15:44   #5 (permalink)
Member: 243158
Thanks Meter: 25
always the same problem phone not power on
module v2.79
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
device-id: B18E7E32
ffs/eeprom chip: 00
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN]_20090331-143003.B0E.bin
Write ...
security area (code #1) calculation...
done
detecting security area (code #2)...
security area (code #2) is absent
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_B18E7E32_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V03B09.BIN_09B2A37C_20090331-143033.B0X.bin
Area: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_B18E7E32_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V03B09.BIN_09B2A37C_20090331-143834.B0X.bin
Finished, time used: 653 sec
Old 03-31-2009, 21:30   #6 (permalink)
Member: 148515
hello!
make format FFS (complete) after you wrote fimrware from support
Old 04-01-2009, 16:47   #7 (permalink)
Member: 243158
Thanks Meter: 25
phone not power on I have the same problem
COM5 [VCP2] selected
module v2.79
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B18E7E32.[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN_F 69250D5].rpl
device-id: B18E7E32
ver. sw 2: UPU25U26V03B09, 2AAF6D09
ffs/eeprom chip: 00
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN]_20090401-125622.B0E.bin
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_B18E7E32_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V03B09.BIN_F69250D5_20090401-125637.B0X.bin
Finished, time used: 129 sec
Old 04-02-2009, 23:32   #8 (permalink)
Member: 148515
hello!
same working phone must be found in order to repair faulty.
full backup taken from working phone must be used for flashing faulty one
Old 05-02-2009, 20:23   #9 (permalink)
Member: 243158
Thanks Meter: 25
thank you .
Old 10-19-2009, 10:07   #10 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
hello!
hi mate
could you please tell me how did you arrive to know that this is for TV8000?
i am trying to fix some TV8000 all with white screen. These are my first ones with pin finder and am finding it very difficult to know which files to use.
inside the phone there is this flash : R901_31MLT_PCB01_GPRS_MT6225_S00.M_RR9013102_M2810 2_V1_0_0_0M0815.BIN which is not in database but as i mentioned before its showing white screen.
thanks for any help
Old 10-19-2009, 10:42   #11 (permalink)
Member: 11325
Thanks Meter: 266
as a follow up. using that flash file rendered the phone not even to power up now
Old 10-19-2009, 11:41   #12 (permalink)
Member: 11325
Thanks Meter: 266
another follow up.
read the flash file from another TV8000 and reflashed this one. again white screen. I am suspecting this white screen problem is actually a hardware problem.
Here are the details and flash file for those who require them. Hope at least they ll help someone.
Yingtai TV8000
Full flash : http://rapidshare.com/files/29500014...120527.B0M.bin
Eeprom : http://rapidshare.com/files/29500023...121051.B0E.bin
6030 mobile not power on, on battery and working fine on power supply kashif_khatri Nokia Digital Core Technology 4 ( DCT-4 ) 1 09-19-2009 02:57
7370 power on on ufs but not power on battrey dereje Nokia Hardware & Hardware Repair 0 05-26-2009 09:25
help 3310 in tornado it power on but with batterie it not power on sofiame2006 Nokia Hardware & Hardware Repair 3 08-02-2005 08:46
G5600 not powers on with sim while without sim powers on :( need help the_frightener LG 1 03-20-2005 06:18
t100 not power on after flash, not power on when original cable is plug GYZMO VLSI, Conexant, Skyworks and Old Models 8 01-07-2004 00:34
Page generated in 0.25555 seconds with 9 queries
