12-24-2007, 20:36 | #3 (permalink) |
Insane Poster Join Date: May 2007 Location: India
Member: 519307 Status: Offline Sonork: 100.1584418 Thanks Meter: 26 | I have kg110 I FLASHES THROUGH INFINITY BOX EVERY VERSION OF FILES BUT THERE IS ONE PROB. BECOMES STILL "CALL END DROPPED" HOW CAN IT BE SLOVED the imei is only 10 degit (xxxxxxxxxx) in the place of 15 degit (xxxxxx-xx-xxxxxx-x) is there any solu in inifinity box or wihch box |
12-25-2007, 08:22 | #4 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 399228 Status: Offline Thanks Meter: 66 | zt199 cable Here u will get it more clear. In rar file there is cable picture made by me. In infinity u must having JTAG CABLE , 1.PIN IS VPP 2.PIN BOX TX 3.PIN BOX RX , LAST 2 PINS GROUND. |
12-25-2007, 12:33 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @amit_varietymob What you talk about ? What JTAG cable ? You must use ordinary Rx/Tx/Gnd wires soldered directly to PCB. It's not a JTAG and our pinout is very easy. If you don't understand word JTAG it's better don't use it ! @ntek open phone and you will se PCB with "SkyWorks" CPU installed on PCB. |
12-26-2007, 13:45 | #8 (permalink) | |
Member: 399228 Status: Offline Thanks Meter: 66 | j tag cable Quote:
12-26-2007, 17:55 | #10 (permalink) |
Member: 399228 Status: Offline Thanks Meter: 66 | cable here is d another look of full cable. I use CABLE AT 106 BEHIND THAT IT IS MENTION JTAG . It was convenint for me that,s why i use that cable. U can use any cable only thing is that u have to solder rx, tx & ground |
02-26-2008, 06:07 | #11 (permalink) | |
No Life Poster Join Date: Dec 2005
Member: 205738 Status: Offline Thanks Meter: 129 | Quote:
did you disconnect skyworks module to get connection? whats this mean?how select module in Infinity Shell as there is not exact such model | |
02-26-2008, 15:04 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello ..:MumbaiGsm:..! just run Chinese miracle program, it will autodetect this model. to get communication with this phone you must disconnect skyworks module (just remove it from phone) after you get connection and make needed with phone- install it back and assemble phone |
09-08-2008, 14:43 | #13 (permalink) |
Insane Poster Join Date: Jan 2005 Location: Bulgaria Age: 49
Member: 104603 Status: Offline Thanks Meter: 13 | I have get conection with skyworks modul and flash the phone, format ... unlock ... when insert simB phone "Opening simB" and after 15 second show "Insert sim" ??? have skyworks moduls reason for this ? |
09-09-2008, 09:26 | #15 (permalink) |
Member: 104603 Status: Offline Thanks Meter: 13 | hello helper, phone have one CPU MT6226BA and I have flashed with some of firmware on support site. And flash with backup read from phone ... /MCU and Eprom/ On skyworks modul phone have "skyworks cx80503-38 - baseband CPU" and FLASH "SST 34HF1641J-70-4E-L1PE" how can fix problem with second sim... |
ztc tv600 pin out please | sancakaziz | Infinity-Box | 15 | 05-09-2008 10:18 |
ztc F688 pin out plz help | pawan_verma51 | Infinity-Box | 1 | 03-14-2008 17:24 |
Need Ztc-A380 pin out | lie_james | Infinity-Box | 4 | 01-19-2008 13:06 |
ztc 8886 pin out...? | shami | Infinity-Box | 3 | 01-04-2008 22:51 |
ZTC 303 pin out (PDA Mobile) | maxieboy | Chinese Cocktail | 2 | 01-03-2008 10:36 |
