10-16-2007, 14:46 | #1 (permalink) |
Freak Poster Join Date: Oct 2004
Member: 87403 Status: Offline Thanks Meter: 6 | narnia 8088 COM4 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: write NOR flash write: Firmware skip: Customization skip: Language Pack skip: Eeprom Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 62 sec Remove/Install battery now ! PS: phone works ok . thank you |
10-16-2007, 19:46 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | It's cable problem, wrong pinout. You must use correct cable and select correct COM port. Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
vertu narnia 8088 security code | MORRISGSM | Various | 0 | 07-04-2008 17:46 |
narnia 8088 dead help me | ufuk112 | Chinese Models & Cloned Phones | 0 | 04-22-2008 20:39 |
Narnia 8088 | GPGIndustries | Infinity-Box | 4 | 09-08-2007 12:49 |
Need 8088 flash | dennt | Motorola Old Legacy (EMMI) | 0 | 04-27-2002 18:35 |
Motorola 8088 | vato | Motorola Old Legacy (EMMI) | 2 | 05-20-2001 23:03 |
