05-08-2010, 15:01 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: World wide
Member: 252975 Status: Offline Thanks Meter: 146 | ZTE 125 dead after unlock module v1.78 Device: ZTE-125 Checking data, wait... Action: write flash write: Firmware ZTE-125_main_lp_COMCEL-P108A7(V)_B01-EnEs-CO01_Nov-13-2007.B1M.bin skip: FFS-1/Customization write: Language Pack ZTE125_LP_ERF-RO-P108A1V1.0.0B06__VDF-P108A1B06-RoFr-RO05.B1P.bin skip: Graphics Pack skip: FFS-2/File system skip: Eeprom Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00BF:7343 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20100508-192941.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20100508-192942.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20100508-192943.B1E.bin backup critical area Done Check memory ... unlocking... lock found lock type #1 found operation done Check memory Done Write ... reset... done Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 24 sec Remove/Install battery now ! |
The Following User Says Thank You to saajith For This Useful Post: |
05-08-2010, 15:20 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Well the log shows that tired to flash the phone but you say you unlock it. First clear whether you tried to flash or unlock the phone. Now try to flash it again with and with a charged battery. And next time if you want to unlock the phone just simply press "SP Unlock" or "User/phone/lock code" in Service tab whatever you required to do. Wr. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
05-08-2010, 15:23 | #3 (permalink) |
Member: 252975 Status: Offline Thanks Meter: 146 | Yes its ask the phone lock then i have sp unlock after unlock also it not unlocked so what i did is gain i did user phone lock code then its success after i try to power on its not power on.... i try to flash then its coming this error msg any solution........ |
05-08-2010, 15:23 | #4 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: TUNISIA Age: 41
Member: 479816 Status: Offline Thanks Meter: 851 | Quote:
UNLOCK not succes...restore backup eeprom. | |
05-08-2010, 15:31 | #6 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Just flash the phone again with complete firmware. Wr. |
05-08-2010, 21:16 | #10 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @saajith select model "BSNL-G200" and flash phone again. Then try to unlock phone like BSNL-G200 model too. |
05-10-2010, 06:35 | #11 (permalink) |
Member: 252975 Status: Offline Thanks Meter: 146 | COM3 [VCP2] selected module v1.78 Device: Digibee-BSNL-G200CF Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... slowest Set Baud Done Connecting ... Connecting Failed Finished, time used: 21 sec Remove/Install battery now ! |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
