08-11-2008, 18:32 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: AL-SATWA DUBAI U.A.E Age: 45
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | ZTE A136 Zong Network Unlock problem after unlock done I can't enter the code in phone so I need flash file of this phone Infinity Teem Please help me Phone modelm is A36 I slect A36 in Pana01 Because Phone Model is not in the list Here is log file COM14 [VCP0] selected Device: ZTE-A36 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 00EC:257E Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-sta_20080811-222617.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: D:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-sec_20080811-222621.B1E.bin reading [eeprom-complete]... file saved: D:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-complete_20080811-222623.B1E.bin reading additional data... done backup critical area Done Check memory... current status: #2, already unlocked already done (mode-0), operation aborted Check memory Failed Finished, Remove/Install battery now ! Time used: 24 sec me wating for your reply |
The Following User Says Thank You to Ramzan For This Useful Post: |
08-29-2008, 17:52 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, read flash from ZTE-A136 (select model A36) and send full flash backup to [email protected] so we will be able to check it. |
08-31-2008, 14:13 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @irfan_shahzad Here is an instruction for you: http:///vbb/showpo...39&postcount=8 |
08-31-2008, 14:26 | #11 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | ZONG All Sim Work -------------------------------------------------------------------------------- hi to all: Zong network introduced new mobile which name is also Zong:but this mobile run only one sim Zong: but i soultion this :zong mobile work to all sim.i tested 100% soultion. first of all u have a spider man and infinity box. boot to spiderman and then open to infinity box .and go to A-Module 1.31. then change the imei and unlock.100% work all sim. |
09-01-2008, 05:38 | #13 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | A Compmay Name Zong Lanuch New Service In Pakistan He Give A Set With Its Sim Card N The Mobile Set Name Is Zong But This Set Is The Brand Of Zte Based Phones Compny Change Its Lcd Only.thanks |
09-01-2008, 10:07 | #15 (permalink) |
No Life Poster Join Date: Jan 2002 Location: 24° 51′ 36″ N, 67°
Member: 8353 Status: Offline Sonork: 113276 Thanks Meter: 335 | i think he is talking about zong "Zte-A136" model which come with Zong package...some users said that its same like zte-125 just lcd difference so u can unlock same like zte-125. but if it is counter block u have to use other tool to unlock it |
02 Nov 2008: LG-KP135, SFR-111, Bird-V5518+, ZTE-A136, Zong-A136 models supported | InfinitySupport | Infinity-Box | 36 | 06-21-2009 10:59 |
Zte A136 Zong model unlock seccefully | themobileshop | Infinity-Box | 1 | 03-05-2009 14:26 |
ZTE-A136,Zong-A136 unlock | MALIKtelecom | Infinity-Box | 1 | 12-18-2008 19:15 |
zte a136 zong unlock | MSCOMMUNICATION | VygisToolbox | 11 | 11-20-2008 11:54 |
Zte a136 zong unlock sucessfuly | saqib2009 | FuriousGold | 0 | 11-16-2008 05:36 |
