02-14-2012, 18:09 | #1 (permalink) |
Junior Member Join Date: May 2010
Member: 1310278 Status: Offline Thanks Meter: 0 | ZTE G X670 dead after unlock 1 repair security area 2 flash with ZTE-X670_32mb_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00 .X670_V1_OG_Z2_FRES_DFFA111_2010-05-14_En_Fr_Es_Orange-Lisbon.B0M.bin (tick smart write and format ffs) 3 unlock with smart fast but still no success. Plz gimme some solution!Here some logs: COM12 [VCP0] selected module v4.15 Device: ZTE-X670_32mb Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot Off chip: 0001:2603:000D status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required rom info detection finished device-id: 37E2730B rom info ver: 07 sw version: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN project-id: X670_V1_OG_Z2_FRES_DFFA111, 09457FC0 code offset: 00000000 ffs offset/size [02]: 01000000/01000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 01000000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA11 detecting firmware build... ................................................. firmware date/time: 2010-05-14 19-33 hw1: ZTEMT25_09A_GEMINI_HW hw2: 09A_ZTEMT25_09A_GEMINI done detecting product-id... .................................................. .................................................. ............................ done detecting languages... ............................................. language parameters detected detected languages: En Fr Es Finished, time used: 1 min 58 sec Remove/Install battery now ! and COM12 [VCP0] selected module v4.15 Device: ZTE-X670_32mb Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware ZTE-X670_32mb_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00 .X670_V1_OG_Z2_FRES_DFFA111_2010-05-14_En_Fr_Es_Orange-Lisbon.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! enhanced security fix enabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2603:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required rom info detection finished device-id: 37E2730B rom info ver: 04 sw version: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X670_V1_Z2_FRES_ BFFA100.BIN project-id: X670_V1_Z2_FRES_BFFA100, 64A900FB code offset: 00000000 ffs offset/size [01]: 00D00000/00300000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 00D00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-X670_32mb_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X670_V 1_Z2_FRES_BFFA100__ffs... file saved: C:\InfinityBox\MModule\ZTE-X670_32mb_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X670_V 1_Z2_FRES_BFFA100__ffs_20120214-182108.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... rpl file not found: c:\InfinityBox\MModule\id.37E2730B.[ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN_C07F4509].rpl rpl file not found: c:\InfinityBox\MModule\id.37E2730B._ZTEMT25_09A_GE MINI_PCB01_GPRS_MT6225_S00.X670_V1_OG_Z2_FRES_DFFA 111.BIN_C07F4509_.rpl rpl file not found: c:\InfinityBox\MModule\backup_security\id.37E2730B .[ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN_C07F4509].rpl rpl file not found: c:\InfinityBox\MModule\backup_security\id.37E2730B ._ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1 _OG_Z2_FRES_DFFA111.BIN_C07F4509_.rpl ==================== warning: unknown firmware: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN_C07F4509 Unknown firmware found (v.4.15, database date: 14.02.2012), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? Area: Firmware flash: EC227E22632260:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: EC227E22632260:18E59F00000000 Finalization Done Finished, time used: 59 min 32 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! smart-card: disconnected This flashfile ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN_C07F4509 is missing on support area. Where i can find it? |
02-14-2012, 20:00 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Friend ! Please, never flash phone if you do not have original full flash backup and you do not know what are you doing exactly ! Now you can flash phone with any flash 32mb file from Infinity-Box support area, phone should be powered-on. Then you have to check imei and unlock phone via "read codes" or "smart fast" unlock method |
02-15-2012, 09:11 | #3 (permalink) | |
Member: 1310278 Status: Offline Thanks Meter: 0 | Quote:
Thanks, but i tried to flash with any 32 mb firmware and still phone no power on. Have same error with version of firmware as log shows error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? If i press yes flashing is going good, but phone not power on. | |
02-15-2012, 13:48 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, It's quite strange. please, try to install previous version of MModule (f.e. 2 or 3 versions back) and try to flash phone again (you can find it in software/updates/archive folder in support area) |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
