09-25-2009, 04:13 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: ina 4 sure
Member: 911645 Status: Offline Thanks Meter: 19 | zte-h500 dead; which file should i use? I got zte-h500 dead, been trying to re-flash phone using 2 firmwares on support area, but no luck, phone still dead.. flashing process went smoothly w/o any error msg, though some questions emerge.. -there are 5 eeprom files on support, 1 repair eeprom calibration and 4 repair ffs..should i use any of these eeprom? if so which one? -when should i use eeprom for calibration repair and ffs repair? -tried to use other tool (cpf) to back-up, and got 16mb flash file, but files on support area (infinity) size are only 2mb, could it be corrupt files or u use kinda compression method on it? -what should i do to revive phone? thank u wbr, rudy |
09-26-2009, 00:50 | #2 (permalink) | |
All files in Infinity-Box support area is internally packed, so 2 Mb file is not an actual flash chip size. firmware + calibration + fat + ffs = full flash. Do you know phone original firmware version ? What is exact phone model name ? | |
09-26-2009, 02:50 | #3 (permalink) |
Member: 911645 Status: Offline Thanks Meter: 19 | here's the name of backed-up phone's original firmware _part_1_of_1_356624010756341_ZTE-H500_20090919-183037.98X.bin exact phone model name? as i know it is zte h500 gsm/cdma 1x dual-mode digital Mobile phone here's the pic [IMG]http://3.bp.********.com/_J-_GDh37_lc/Srsa-FDNhyI/AAAAAAAAADM/c7_zbUo39gc/s400/DSC00161.JPG[/IMG] [IMG]http://4.bp.********.com/_J-_GDh37_lc/Srsa-pgIkeI/AAAAAAAAADU/bEKkwAdY4LA/s400/DSC00162.JPG[/IMG] it has 18 pins on charge connector, i use L18a cable |
09-26-2009, 04:14 | #4 (permalink) | |
Member: 911645 Status: Offline Thanks Meter: 19 | tried to fullflash phone Quote:
here's the log Code: Loading data, wait... S/N: 33D9:xxxx Wait... Device: ZTE-H500 Done Loading file v.04... ZTE-H500_GSM_KZH500V1.0.0B15_En_Ru.98M.bin loaded Loading file v.04... ZTE-H500_repair_eeprom_calibration_01.98E.bin loaded ---------- COM2 [VCP0] selected module v1.32 Device: ZTE-H500 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware Skip: File system Skip: Language pack Write: Eeprom "smart write" enabled Boot ... Phone should be Switched OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: EC22E000000000:70E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 35662401039 672 file saved: C:\Program Files\InfinityBox\AModule\eeprom_35662401039 672_ZTE-H500_20090926-104609.98E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware flash: EC22E000000000:70E59F00000000 Write: Eeprom flash: EC22E000000000:70E59F00000000 Write Done Finished, time used: 776 sec Remove/Install battery now ! -------------------- Loading file v.04... ZTE-H500_repair_filesystem_fat_01.98F.bin loaded -------------------- COM2 [VCP0] selected module v1.32 Device: ZTE-H500 Checking data, wait... advanced flash detection enabled Action: flash write Skip: Firmware Skip: File system Skip: Language pack Write: Eeprom "smart write" enabled Boot ... Phone should be Switched OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: EC22E000000000:70E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 35662401039 672 file saved: C:\Program Files\InfinityBox\AModule\eeprom_35662401039 672_ZTE-H500_20090926-110352.98E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Eeprom flash: EC22E000000000:70E59F00000000 Write Done Finished, time used: 83 sec Remove/Install battery now ! ------------------------ Loading file v.04... ZTE-H500_repair_filesystem_ffs_01.98F.bin loaded ----------------------------- COM2 [VCP0] selected module v1.32 Device: ZTE-H500 Checking data, wait... advanced flash detection enabled Action: flash write Skip: Firmware Skip: File system Skip: Language pack Write: Eeprom "smart write" enabled Boot ... Phone should be Switched OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: EC22E000000000:70E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 35662401039 672 file saved: C:\Program Files\InfinityBox\AModule\eeprom_35662401039 672_ZTE-H500_20090926-110643.98E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Eeprom flash: EC22E000000000:70E59F00000000 Write Done Finished, time used: 76 sec Remove/Install battery now ! | |
09-26-2009, 08:59 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If phone can not power-on at all after you have flashed it with firmware + calibration + fat + ffs - I think you have a reason to check phone hardware. |
which flash file should I use for KE970? need chinese language after unlocking. | snowtown | FuriousGold | 4 | 04-25-2008 00:16 |
which TP should i use for X-7 | ::.imeimate.:: | SAGEM JTAG UNLOCKER | 4 | 10-12-2005 13:46 |
which file should i use to flash d500 orange | gamdadda | NSPRO | 2 | 03-13-2005 19:51 |
Nokia 3120 - which cable should I use? | duwi | UFS2 + UFS3-Tornadoflasher | 2 | 01-29-2005 18:15 |
Which flashfile should I use for 1018 | birom | Old Ericsson Phones & Sony Phones | 0 | 06-02-2000 13:15 |
