01-18-2020, 11:29 | #1 (permalink) |
Freak Poster Join Date: Apr 2016 Location: South Africa /Pakistan Age: 29
Member: 2555393 Status: Offline Thanks Meter: 268 | ZTE L130 KICKA 4 VODACOME Flashing Problem Open : SPD_PROG.xml Reading package ... Read package finished! Created by Infinity-Box (c) 2019 Chinese Miracle II : Spreadtrum / UniSoc Service Module Device Info file : _Android_info.txt Patch Level : PPR1.180610.011 Display ID : VDC_ZA_L130_V1.1 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-02-05 Build Time : 1552614124 Product Model : ZTE Blade L130 Product Brand : ZTE Product Name : VDC_ZA_P731K30 Product Device : P731K30 Product Manfct : ZTE Product Info : P731K30 Product Name : VDC_ZA_P731K30 Product Board : sp7731e_1h20 Board Platform : sp7731e Operation : Flash Firmware [ v2.04 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x26 PMTMng : Update PMT Ok! UBOOT : u-boot.bin UBOOT : u-boot.bin CODE : sml.bin CODE : sml.bin CODE : tos.bin CODE : tos.bin CODE : vbmeta.img CODE : vbmeta.img CODE : dtb.img CODE : dtbo.img CODE : deltanv_w.bin CODE : pm_sys.bin CODE : modem_w.bin CODE : gdsp_w.bin ERASE : FLASH_W CODE : modem_wcn.img CODE : gnssmodem.bin CODE : gnssbdmodem.bin CODE : boot_logo.bmp CODE : fastboot_logo.bmp FSIMG : persist.img ERASE : MISC CODE : boot.img CODE : recovery.img FSIMG : system.img Failed to update block! ERROR : 0000008E:00000000FF7F0000 INT : WAIT TIMEOUT! DEVICE PROBLEM or WRONG FDL! Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
01-24-2020, 14:23 | #3 (permalink) |
Member: 2555393 Status: Offline Thanks Meter: 268 | flash done with Pac file from easy firmware. But fail to flash with CM2SP2 backup firmware. please add network unlock for zte l130 etc. |
01-24-2020, 18:44 | #4 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Not matter which model it is. | |
