11-26-2013, 09:48 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | It can not be true that no log present. Infinity software save all operation log in log file. Please, check folder with software module, you will see file with name operation.log If phone become dead you can restore special backup file, but we have to check process log first. |
12-27-2013, 17:53 | #5 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 42
Member: 106391 Status: Offline Thanks Meter: 37 | Code: ==== [20.11.2013 12:55:10] ==== COM49 [VCP0] selected module v1.78 Device: Vodafone-225 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:22A0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: c:\InfinityBox\Pana01\Vodafone-225_eeprom-static_20131120-125528.B1E.bin loading data... data loaded reading eeprom-security... file saved: c:\InfinityBox\Pana01\Vodafone-225_eeprom-security_20131120-125529.B1E.bin reading eeprom-complete... file saved: c:\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20131120-125535.B1E.bin reading additional data... file saved: c:\InfinityBox\Pana01\Vodafone-225_lock-area_20131120-125548.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 51 sec Remove/Install battery now ! ==== [20.11.2013 13:00:04] ==== COM49 [VCP0] selected module v1.78 Device: Vodafone-225 Checking data, wait... Action: "sp-unlock" restore Boot ... Press and HOLD Power button now ! error: wrong boot answer #1: Release Power button now Boot Failed Finished, time used: 12 sec Remove/Install battery now ! ==== [20.11.2013 13:00:25] ==== COM49 [VCP0] selected module v1.78 Device: Vodafone-225 Checking data, wait... Action: "sp-unlock" restore Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:22A0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: c:\InfinityBox\Pana01\Vodafone-225_eeprom-static_20131120-130042.B1E.bin loading data... data loaded reading eeprom-security... file saved: c:\InfinityBox\Pana01\Vodafone-225_eeprom-security_20131120-130043.B1E.bin reading eeprom-complete... file saved: c:\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20131120-130049.B1E.bin reading additional data... file saved: c:\InfinityBox\Pana01\Vodafone-225_lock-area_20131120-130102.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 50 sec Remove/Install battery now ! Loading file v.02... error: data error ! Loading failed, probably damaged data file Loading file v.02... Vodafone-225_eeprom-complete_20131120-125535.B1E.bin loaded ==== [20.11.2013 13:04:43] ==== COM49 [VCP0] selected module v1.78 Device: Vodafone-225 Checking data, wait... Action: write flash skip: Firmware skip: FFS-1/Customization skip: Language Pack skip: Graphics Pack skip: FFS-2/File system write: Eeprom Vodafone-225_eeprom-complete_20131120-125535.B1E.bin Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:22A0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: c:\InfinityBox\Pana01\Vodafone-225_eeprom-static_20131120-130511.B1E.bin loading data... data loaded reading eeprom-security... file saved: c:\InfinityBox\Pana01\Vodafone-225_eeprom-security_20131120-130512.B1E.bin reading eeprom-complete... file saved: c:\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20131120-130518.B1E.bin backup critical area Done Check memory ... unlocking... error: unknown firmware, read flash and send to support error: operation failed Check memory Done Write ... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 46 sec Remove/Install battery now ! Loading file v.01... Loading failed, probably damaged data file WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [20.11.2013 13:06:29] ==== COM49 [VCP0] selected module v1.78 Device: Vodafone-225 Checking data, wait... Action: reset settings ("format ffs") Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:22A0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: c:\InfinityBox\Pana01\Vodafone-225_eeprom-static_20131120-130651.B1E.bin loading data... data loaded reading eeprom-security... file saved: c:\InfinityBox\Pana01\Vodafone-225_eeprom-security_20131120-130652.B1E.bin reading eeprom-complete... file saved: c:\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20131120-130659.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 31 sec Remove/Install battery now ! oke find it |
