07-15-2009, 04:41 | #1 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 235703 Status: Offline Thanks Meter: 39 | 5130 strange problem |
07-15-2009, 05:09 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | most of the times, allways battery problem, if not, check for how much voltage is being given by the cellphone from charger to cellphone to battery. if voltage is low, try changing charging IC. also check if the unit is grounded or not. |
07-15-2009, 05:50 | #4 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
Apply full chrged battery first check battery connected to bsi properly if problem not solved then replace power amplifier if still no result then wash board and rehot uem & upp carefully | |
5130 strange problem | Riteshgpt60 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 17 | 10-03-2010 16:04 |
I8510 strang problem | naslejavan | QUALCOMM Models (3G) | 4 | 03-30-2010 09:32 |
n95 (rm-159) strang problem | Tayyab_raja777 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 14:45 |
5130 strange problem plz help | rana_jee | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-01-2010 13:29 |
5130 strange problem | .::Indrojith::. | Nokia Hardware & Hardware Repair | 6 | 08-24-2009 08:00 |
